Drop superfluous #address-cells and #size-cells, rename
key-nodes to individual names and also use the key constants
intead of numbers.
Reported-by: Julien Chauveau <chauveau.julien@gmail.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Rob Herring <robh@kernel.org>
Keyboard driver for GPIO buttons(gpio-keys) checks for the legacy
"gpio-key,wakeup" boolean property to enable gpio buttons as wakeup
source.
Few dts files assign value "1" to gpio-key,wakeup and in one instance a
value "0" is assigned probably assuming it won't be enabled as a wakeup
source. Since the presence of the boolean property indicates it is
enabled, value of "0" have no value.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property which inturn fixes the above mentioned issue.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Add support for the IR receiver present on the R89 board.
The memory node is supposed to contain a device_type property marking
it as memory. The currently included boards miss this property.
This board is used in some TV-boxes like for example the Beelink R89 or
Tronsmart R28.
The board itself follows the reference design for the most part. But
there are no schematics available it seems, so some things should be
taken with a grain of salt.
Reviewed-by: Romain Perier <romain.perier@gmail.com>
