Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Commit 6c42db30d8c8 introduced audio support based on alsa ucm profiles
taken from the ChromeOS userspace. Both in the kernel as well as alsa
they were named (and matched against) ROCKCHIP-I2S. Audio profiles are
very much board-specific and hogging the ROCKCHIP-I2S name would make
it harder for future boards and also is misleading.
For Veyron boards the audio setup is similar over all variants, so
VEYRON-I2S is a more suitable name. This rename also was merged into
the alsa ucm profile so both userspace and kernel match and the old
naming was never released in any alsa or kernel release.
Fixes: 6c42db30d8c8 ("ARM: dts: rockchip: Add shared file for audio on rk3288-veyron boards")
Set i2s block to "okay", add sound node for max98090 with gpios for
HP and Mic detect and pinctrl, and add a max98090 device and ts3a227e to
the correct i2c bus.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
