This is like commit 0ca87bd5baa6 ("ARM: dts: rockchip: Add pin names
for rk3288-veyron-jerry") and other similar commits, but for the
veyron fievel board (and tiger, which includes the fievel .dtsi).
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Fix/improve a few things for veyron fievel/tiger:
- move 'vccsys' regulator from tiger to fievel, both boards
have it (and tiger includes the fievel .dtsi)
- move 'ext_gmac' node below regulators
- fix GPIO ids of vcc5_host1 and vcc5_host2 regulators
- remove reset configuration from 'gmac' node, this is already done
in rk3288.dtsi
- fixed style issues of some multi-line comments
- switch 'vcc18_lcdt', 'vdd10_lcd' and 'vcc33_ccd' regulators off
during suspend
- no pull-up on the Bluetooth wake-up pin, there is an external
pull-up. The signal is active low, add the 'bt_host_wake_l'
pinctrl config
- move BC 1.2 pins up in the pinctrl config to keep 'wake only' pins
separate
- add BC 1.2 pins to sleep config
Fixes: 0067692b662e ("ARM: dts: rockchip: add veyron-fievel board")
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Also known as AOpen Chromebox Mini.
