Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The panel which jaq uses requires the pwm duty cycle larger than 3%,
when the backlight status from power off to power on, otherwise the
backlight will flush, so we modify the second brightness-level to 8,
and when the backlight from power off to power on the pwm duty cycle
will larger than 3%.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Tested-by: Douglas Anderson <dianders@chromium.org>
The panels need a bit of time to actually turn on. If this isn't
observed, this results in problems when trying talk to the panels
and thus produces detection errors. 100ms seem to be a safe value
for the time being.
The edp hotplug pin is fixed on the soc side, anybody wanting to use it
will need the same definition anyway, so move it to a common location.
a.k.a. Haier Chromebook 11, and others
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
