[ Upstream commit 8ef1ba39a9fa53d2205e633bc9b21840a275908e ]
This is similar to commit e6186820a745 ("arm64: dts: rockchip: Arch
counter doesn't tick in system suspend"). Specifically on the rk3288
it can be seen that the timer stops ticking in suspend if we end up
running through the "osc_disable" path in rk3288_slp_mode_set(). In
that path the 24 MHz clock will turn off and the timer stops.
To test this, I ran this on a Chrome OS filesystem:
before=$(date); \
suspend_stress_test -c1 --suspend_min=30 --suspend_max=31; \
echo ${before}; date
...and I found that unless I plug in a device that requests USB wakeup
to be active that the two calls to "date" would show that fewer than
30 seconds passed.
NOTE: deep suspend (where the 24 MHz clock gets disabled) isn't
supported yet on upstream Linux so this was tested on a downstream
kernel.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[ Upstream commit d040e4e8deeaa8257d6aa260e29ad69832b5d630 ]
The device tree compiler yells like this:
Warning (unit_address_vs_reg):
/gpu-opp-table/opp@100000000:
node has a unit name, but no reg property
Let's match the cpu opp node names and use a dash.
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
[ Upstream commit 4e943a890cef42e90f43ce6be64728a290b97c55 ]
dtc now gives the following warning:
arch/arm/boot/dts/rk3288-tinker.dtb: Warning (sound_dai_property): /sound/simple-audio-card,codec: Missing property '#sound-dai-cells' in node /hdmi@ff980000 or bad phandle (referred from sound-dai[0])
Add the missing #sound-dai-cells property.
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: linux-rockchip@lists.infradead.org
Signed-off-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into next/dt
Pull "second round of Rockchip dts32 changes for 4.14" from Heiko Stübner:
A lot of attention for the rv1108 soc targetted at media-processing
(usb, operating points, spi, pwm, adc, watchdog, i2c and devices for
its evb).
RK3228/3229 gets iommu and spi nodes. Similar to the rk3288 which
also gets some more iommu nodes as well as getting converted to 64
bit addresses due to wanting to address more than 4GB of memory
via LPAE.
* tag 'v4.14-rockchip-dts32-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
ARM: dts: rockchip: enable usb for rv1108-evb
ARM: dts: rockchip: add usb nodes for rv1108 SoCs
dt-bindings: update grf-binding for rv1108 SoCs
ARM: dts: rockchip: add cpu power supply for rv1108 evb
ARM: dts: rockchip: add cpu opp table for rv1108
ARM: dts: rockchip: add rk322x iommu nodes
ARM: dts: rockchip: add accelerometer bma250e dt node for rv1108 evb
ARM: dts: rockchip: add pmic rk805 dt node for rv1108 evb
ARM: dts: rockchip: add pwm backlight for rv1108 evb
ARM: dts: rockchip: add pwm dt nodes for rv1108
ARM: dts: rockchip: add spi dt node for rv1108
ARM: dts: rockchip: add saradc support for rv1108
ARM: dts: rockchip: add watchdog dt node for rv1108
ARM: dts: rockchip: add i2c dt nodes for rv1108
clk: rockchip: fix up indentation of some RV1108 clock-ids
clk: rockchip: rename the clk id for HCLK_I2S1_2CH
clk: rockchip: add more clk ids for rv1108
ARM: dts: rockchip: add more iommu nodes on rk3288
ARM: dts: rockchip: convert rk3288 device tree files to 64 bits
ARM: dts: rockchip: add spi node and spi pinctrl on rk3228/rk3229
Add IEP/ISP/VPU/HEVC iommu nodes
Signed-off-by: Simon Xue <xxm@rock-chips.com>
In order to be able to use more than 4GB of RAM when the LPAE is
activated, the dts must be converted in 64 bits.
Signed-off-by: Tao Huang <huangtao@rock-chips.com>
The binding specifies the actual implementations only (mali-t760
for example) but not the arm,mali-midgard used in some vendor kernels.
So drop that compatible property from the rk3288 where it had slipped in.
Also fix the node name which should be a generic gpu@...
Add Mali GPU device tree node for the rk3288 SoC, with devfreq
opp table.
Signed-off-by: Guillaume Tucker <guillaume.tucker@collabora.com>
Tested-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
dw-mmc got its reset-properties specified, so add the softresets
for it in rk3288.
Reviwed-by: Shawn Lin <shawn.lin@rock-chips.com>
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
when pd power on/off, the qos regs need to save and restore.
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
Pull ARM DT updates from Arnd Bergmann:
"Lots of changes as usual, so I'm trying to be brief here. Most of the
new hardware support has the respective driver changes merged through
other trees or has had it available for a while, so this is where
things come together.
We get a DT descriptions for a couple of new SoCs, all of them
variants of other chips we already support, and usually coming with a
new evaluation board:
- Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices
- Qualcomm MDM9615 LTE baseband
- NXP imx6ull, the latest and smallest i.MX6 application processor variant
- Renesas RZ/G (r8a7743 and r8a7745) application processors
- Rockchip PX3, a variant of the rk3188 chip used in Android tablets
- Rockchip rk1108 single-core application processor
- ST stm32f746 Cortex-M7 based microcontroller
- TI DRA71x automotive processors
These are commercially available consumer platforms we now support:
- Motorola Droid 4 (xt894) mobile phone
- Rikomagic MK808 Android TV stick based on Rockchips rx3066
- Cloud Engines PogoPlug v3 based on OX820
- Various Broadcom based wireless devices:
- Netgear R8500 router
- Tenda AC9 router
- TP-LINK Archer C9 V1
- Luxul XAP-1510 Access point
- Turris Omnia open hardware router based on Armada 385
And a couple of new boards targeted at developers, makers or
industrial integration:
- Macnica Sodia development platform for Altera socfpga (Cyclone V)
- MicroZed board based on Xilinx Zynq FPGA platforms
- TOPEET itop/elite based on exynos4412
- WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615
- NextThing CHIP Pro gadget
- NanoPi M1 development board
- AM571x-IDK industrial board based on TI AM5718
- i.MX6SX UDOO Neo
- Boundary Devices Nitrogen6_SOM2 (i.MX6)
- Engicam i.CoreM6
- Grinn i.MX6UL liteSOM/liteBoard
- Toradex Colibri iMX6 module
Other changes:
- added peripherals on renesas, davinci, stm32f429, uniphier, sti,
mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm,
mvebu, allwinner, broadcom, exynos, zynq
- Continued fixes for W=1 dtc warnings
- The old STiH415/416 SoC support gets removed, these never made it
into products and have served their purpose in the kernel as a
template for teh newer chips from ST
- The exynos4415 dtsi file is removed as nothing uses it.
- Intel PXA25x can now be booted using devicetree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits)
arm: dts: zynq: Add MicroZed board support
ARM: dts: da850: enable high speed for mmc
ARM: dts: da850: Add node for pullup/pulldown pinconf
ARM: dts: da850: enable memctrl and mstpri nodes per board
ARM: dts: da850-lcdk: Add ethernet0 alias to DT
ARM: dts: artpec: add pcie support
ARM: dts: add support for Turris Omnia
devicetree: Add vendor prefix for CZ.NIC
ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node
ARM: dts: berlin2q-marvell-dmp: fix regulators' name
ARM: dts: Add xo to sdhc clock node on qcom platforms
ARM: dts: r8a7794: Add device node for PRR
ARM: dts: r8a7793: Add device node for PRR
ARM: dts: r8a7792: Add device node for PRR
ARM: dts: r8a7791: Add device node for PRR
ARM: dts: r8a7790: Add device node for PRR
ARM: dts: r8a7779: Add device node for PRR
ARM: dts: r8a73a4: Add device node for PRR
ARM: dts: sk-rzg1e: add Ether support
ARM: dts: sk-rzg1e: initial device tree
This is not needed as the gadget now fully supports DMA and it can
autodetect it. This was initially added because gadget DMA mode was only
partially implemented so could not be automatically enabled.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
In drivers/mmc/core/host.c, there is "max-frequency" property.
It should be same behavior. So use the "max-frequency" instead of
"clock-freq-min-max".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Finley Xiao <finley.xiao@rock-chips.com>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
"Node /memory has a reg or ranges property, but no unit name"
The disassembled DTB are almost the same, besides empty chosen nodes
being removed. So the change should not have a functional impact.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
"These are as usual a very large number of mostly boring updates to
enable devices in existing machines, or to fix minor bugs. Notably, an
ongoing treewide effort to fix warnings caused by an update to the
device tree compiler. These are enabled with "make W=1" at the moment
but can hopefully become the default once all issues have been
addressed.
No new SoC platform is added this time around (Armada 395 and Orion
mv88f5181 are slight variations of existing ones), but a significant
number of new dts files are added, which I list by platform:
- Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets,
Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite,
Olimex A33-Olinuxino, and Nano Pi Neo single-board computers
- ARM Realview: all supported machines (ported from board files)
- Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and
BCM958622hr reference boards for Northstar platform, Raspberry Pi
Zero single-board computer
- Marvell EBU: Netgear WNR854T router (ported from board file),
Armada 395 SoC platform and GP board Armada 390 DB development
board
- NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x
single-board computer, Technologic Systems TS-4900 and Engicam
IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board
- Qualcomm: LG Nexus 5 Phone
- Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards
- Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288
Reload platform
- ST Microelectronics STi: B2260 (96boards) single-board computer
- TI Davinci: OMAP-L138 LCDK Development kit
- TI OMAP: beagleboard-x15 rev B1 single-board computer"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits)
ARM: dts: sony-nsz-gs7: add missing unit name to /memory node
ARM: dts: chromecast: add missing unit name to /memory node
ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node
ARM: dts: berlin2: Add missing unit name to /soc node
ARM: dts: berlin2cd: Add missing unit name to /soc node
ARM: dts: berlin2q: Add missing unit name to /soc node
ARM: dts: berlin2: Remove skeleton.dtsi inclusion
ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion
ARM: dts: berlin2q: Remove skeleton.dtsi inclusion
arm: dts: berlin2q: enable all wdt nodes unconditionally
arm: dts: berlin2: enable all wdt nodes unconditionally
ARM: dts: omap5-igep0050.dts: Use tabs for indentation
ARM: dts: Fix igepv5 power button GPIO direction
ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node
ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes
ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
SARADC controller needs to be reset before programming it, otherwise
it will not function properly.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Rockchip platform use a SYSCON mapped register store
the reboot mode magic value for bootloader to use when
system reboot. So add syscon-reboot-mode driver DT node
for rk3xxx/rk3036/rk3288 based platform
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
The rk3288 usbphy is completely enclosed in the general register files
and the updated binding allows it to be a subnode of the GRF now.
So move the node appropriately.
Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
In order to use Wake-on-Lan on RK3288 integrated MAC, we need to wake-up
the CPU on the PMT interrupt when the MAC and the PHY are in low power mode.
Adding the interrupt declaration.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
io-voltage control is actually part of the grf, so move the node under the
newly available grf simple-mfd.
To minimize duplicate code, the core node and compatible property
gets placed in the core rk3288.dtsi while the individual boards
now only need to enable it and add the necessary supply properties.
In order to be standard to manage for rockchip SoCs, move the thermal
data into rk3288 dtsi, we needn't to add a new file for thermal.
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Eduardo Valentin <edubezval@gmail.com>
The edp-phy control is a part of the General Register Files and
with a recent patch in 4.6 the phy driver can now also handle this
correctly, so move the dts node under the GRF as well.
Similar to the pmu, the general register files contain a lot of different
setting bits grouped into general registers, but also some somewhat special
entities like the controls for some phy-blocks or the io-voltage control.
To be able to move these blocks under the grf node where they actually
belong, make it a simple-mfd.
The edp hotplug pin is fixed on the soc side, anybody wanting to use it
will need the same definition anyway, so move it to a common location.
Tested-by: Douglas Anderson <dianders@chromium.org>
Add the rk3288 edp node and its hooks into the display-subsystem.
Add the core device node of the edp-phy on rk3288 socs.
The mipi controller node does contain an unused reg property as well as
unnecessary #address-cells and #size-cells properties for subnodes
not using addresses, so remove those to also make dtc happy.
Acked-by: Rob Herring <robh@kernel.org>
The usbphy subnodes do have a reg property but no unitname, add them.
The power-domain sub-nodes do have reg properties, but so far are
missing the expected unit names. So add the missing ones.
The MIPI controllers are part of the VIO power domain so add the
necessary property to indicate this for the controller we support.
Signed-off-by: John Keeping <john@metanate.com>
These must be translated from the values in the TRM by subtracting 32,
which has not been done. The SPDIF interrupt is also off-by-one.
This isn't currently used by the driver but the correct value is 19
since DSIHOST0 is 51 in the TRM and the GIC offset requires 32 to be
subtracted.
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
Pl330 integrated in rk3288 platform doesn't support
DMAFLUSHP function. So we add arm,pl330-broken-no-flushp quirk
for it.
Signed-off-by: Addy Ke <addy.ke@rock-chips.com>
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Sonny Rao <sonnyrao@chromium.org>
Add the #clock-cells properties for the usbphy nodes as they
provide the pll-clocks now.
Reviewed-by: Michael Turquette <mturquette@baylibre.com>
The EDP 24M clock can be fed either by an SoC internal fixed clock or
from an external IC. Change the default parent to the internal clock in
the main rk3288 dtsi, to ensure (by default) it gets setup with a
non-orphaned clock (hardware defaults to the externa clock).
This prevents potential issues when the clock framework get support for
deferring on orphaned clocks, while specific boards can always change
the parent clock if an external input is preferred.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Add a mipi_dsi node, and also add mipi_dsi endpoints to vopb and vopl
output port nodes.
Signed-off-by: Chris Zhong <zyw@rock-chips.com>
Another new soc - the rk3228 quad-core cortex-a7, a new rk3036 board,
support for the efuses on Rockchip socs and some improvements for
rk3288 regulators.
* tag 'v4.5-rockchip-dts32-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
ARM: dts: rockchip: add the kylin board for rk3036
ARM: dts: rockchip: add the sdio/sdmmc node for rk3036
ARM: dts: rockchip: fix the pinctrl bias settings for rk3036
ARM: dts: rockchip: add eFuse node for rk3188 SoCs
ARM: dts: rockchip: add eFuse node for rk3066a SoCs
ARM: dts: rockchip: add eFuse config of rk3288 SoC
ARM: dts: rockchip: add rk3228-evb board
ARM: dts: rockchip: add core rk3228 dtsi
clk: rockchip: Add the clock ids of rk3288 eFuses
ARM: dts: rockchip: Fix typo in rk3288 sdmmc card detect pin name
ARM: dts: rockchip: fix voltage ranges for rk3288-evb-act8846 board
ARM: dts: rockchip: move the public part to rk3288-evb common
ARM: dts: rockchip: add 2 regulators for rk3288-evb-act8846
ARM: dts: rockchip: correct the name of REG8 for rk3288-evb-act8846
clk: rockchip: add dt-binding header for rk3228
clk: rockchip: add id for mipidsi sclk on rk3288
This patch add the eFuse dt config of rk3288 SoC.
Signed-off-by: ZhengShunQian <zhengsq@rock-chips.com>
Merge "rockchip dts32 changes for 4.5" from Heiko Stuebner:
First round of arm devicetree changes.
Among the bigger changes are two new Veyron boards, support for
the dual-core cortex-a7 rk3036 soc and addition of support for
the crypto engine of the rk3288. Smaller changes include some
IR receivers, updates of thermal settings more reflecting real-
life and testing-results.
* tag 'v4.5-rockchip-dts32-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
ARM: dts: rockchip: add gpio-ir-receiver to the R89 board
ARM: dts: rockchip: add touchscreen node to veyron minnie
ARM: dts: rockchip: add veyron-mickey board
ARM: dts: rockchip: add veyron-brain board
ARM: dts: rockchip: make sure edp_24m is associated to xin24m on veyron
ARM: dts: rockchip: override thermal settings on veyron-speedy
ARM: dts: rockchip: update the thermal management on rk3288
ARM: dts: rockchip: Add Crypto node for rk3288
ARM: dts: rockchip: add rk3036-evb board
ARM: dts: rockchip: add core rk3036 dtsi
clk: rockchip: add dt-binding header for rk3036
clk: rockchip: add an id for rk3288 crypto clk
ARM: dts: rockchip: Add IR receiver to RK3288 Radxa Rock 2 Square
ARM: dts: rockchip: add channels properties for i2s
ARM: dts: rockchip: set system-power-controller property on rk3288-rock2
ARM: dts: rockchip: Setup rk3066/rk3188 ethernet0 alias for u-boot
ARM: dts: rockchip: Setup rk3288 ethernet0 alias for u-boot
The card detect pin is currently called sdmcc-cd.
This patch fixes the typo and renames the pin to sdmmc-cd.
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
Add Crypto node for rk3288 including crypto controller and dma clk.
Signed-off-by: Zain Wang <zain.wang@rock-chips.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
add playback and capture properties to compatible various chips.
Signed-off-by: Sugar Zhang <sugar.zhang@rock-chips.com>
Add an ethernet0 alias for the RK3288 mac interface so
that u-boot can find the device-node and fill in the mac address on
boards that support a wired network interface.
Add the "init" anf "sleep" pinctrl as the OTP gpio state.
We need the OTP pin is gpio state before resetting the TSADC controller,
since the tshut polarity will generate a high signal.
"init" pinctrl property is defined by Doug's Patch[0].
Patch[0]:
https://patchwork.kernel.org/patch/7454311/
"As usual, this is the massive branch we have for each release. Lots
of various updates and additions of hardware descriptions on existing
hardware, as well as the usual additions of new boards and SoCs.
This is also the first release where we've started mixing 64- and
32-bit DT updates in one branch.
(Specific details on what's actually here and new is pretty easy to
tell from the diffstat, so there's little point in duplicating listing
it here)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (499 commits)
ARM: dts: uniphier: add system-bus-controller nodes
ARM64: juno: disable NOR flash node by default
ARM: dts: uniphier: add outer cache controller nodes
arm64: defconfig: Enable PCI generic host bridge by default
arm64: Juno: Add support for the PCIe host bridge on Juno R1
Documentation: of: Document the bindings used by Juno R1 PCIe host bridge
ARM: dts: uniphier: add I2C aliases for ProXstream2 boards
dts/Makefile: Add build support for LS2080a QDS & RDB board DTS
dts/ls2080a: Add DTS support for LS2080a QDS & RDB boards
dts/ls2080a: Update Simulator DTS to add support of various peripherals
dts/ls2080a: Remove text about writing to Free Software Foundation
dts/ls2080a: Update DTSI to add support of various peripherals
doc: DTS: Update DWC3 binding to provide reference to generic bindings
doc/bindings: Update GPIO devicetree binding documentation for LS2080A
Documentation/dts: Move FSL board-specific bindings out of /powerpc
Documentation: DT: Add entry for FSL LS2080A QDS and RDB boards
arm64: Rename FSL LS2085A SoC support code to LS2080A
arm64: Use generic Layerscape SoC family naming
ARM: dts: uniphier: add ProXstream2 Vodka board support
ARM: dts: uniphier: add ProXstream2 Gentil board support
The drive/sample clocks can be phase shifted. The drive clock
could be used in a future patch to adjust hold times. The sample
clock is used for tuning.
Signed-off-by: Alexandru M Stan <amstan@chromium.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
