commit 1a1b698b115467242303daf5fe1d3c9886c2fa17 upstream.
The watchdog irq is actually SPI 79, which translates to the original
111 in the manual where the SPI irqs start at 32.
The current dw_wdt driver does not use the irq at all, so this issue
never surfaced. Nevertheless fix this for a time we want to use the irq.
Fixes: 2ab557b72d46 ("ARM: dts: rockchip: add core rk3288 dtsi")
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
This block should not be enabled by default or else if the kconfig is set,
it will try to load/probe even if there's no phy connected.
Signed-off-by: Alexandru M Stan <amstan@chromium.org>
This patch adds a device_node for RK3288 SoC usb phy. It also
defines the phy to be used by three usb controllers: usb_host0/1
and usb_otg.
Signed-off-by: Yunzhi Li <lyz@rock-chips.com>
Tested-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Currently the hdmi driver is using one of the soc i2c busses for ddc probing
and while documentation always specifies i2c5 as hdmi-i2c it could very well
be any other bus as well.
Therefore this is a property of the board and should be specified there.
Add the clock property for the watchdog on rk3288 socs.
The rk3288 board uses the architected timers and these ones are shutdown when
the cpu is powered down. There is a need of a broadcast timer in this case to
ensure proper wakeup when the cpus are in sleep mode and a timer expires.
Add the timer node for the broadcast timer.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Add an hdmi node, and also add hdmi endpoints to vopb and vopl
output port nodes.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Signed-off-by: Yakir Yang <ykk@rock-chips.com>
Reviewed-by: Daniel Kurtz <djkurtz@chromium.org>
Tested-by: Daniel Kurtz <djkurtz@chromium.org>
Add devicetree nodes for rk3288 VOP (Video Output Processors), and the
top level display-subsystem root node.
Later patches add endpoints (eDP, HDMI, LVDS, etc) that attach to the
VOPs' output ports.
Signed-off-by: Daniel Kurtz <djkurtz@chromium.org>
Signed-off-by: Mark yao <mark.yao@rock-chips.com>
Reviewed-by: Stephane Marchesin <marcheu@chromium.org>
add gmac info in rk3288.dtsi for GMAC driver
changes since v2:
1. add drive-strength in the pinctrl settings
Signed-off-by: Roger Chen <roger.chen@rock-chips.com>
add pmu sram node for suspend, add global_pwroff pinctrl.
The pmu sram is used to store the resume code.
global_pwroff is held low level at work, it would be pull to high
when entering suspend. reference this in the board DTS file since
some boards need it.
Signed-off-by: Tony Xie <xxx@rock-chips.com>
Signed-off-by: Chris Zhong <zyw@rock-chips.com>
All of mmc controllers include SDMMC, SDIO0, SDIO1, and EMMC on RK3288
are limited to 150Mhz. It was mainly caused by two reasons:
- RK3288's IO pad(except DDR IO pad) is generic, which can only support
the max of 150Mhz.
- Mmc controller was designed at 150Mhz, and the pressure test by IC team
was based on this freequency point.
Signed-off-by: Addy Ke <addy.ke@rock-chips.com>
This will enable use of physical arch timers on rk3288, where each
core comes out of reset with a different virtual offset. Using
physical timers will help with SMP booting on coreboot and older
u-boot and should also allow suspend-resume and cpu-hotplug to work on
all firmwares.
Firmware which does initialize the cpu registers properly at boot and
cpu-hotplug can remove this property from the device tree.
Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
We now have the physical-timers patches lined up as a dependency in this same
branch, so we can revert the temporary disablement.
This reverts commit b77d43943ea83997c6c37b8831d1561981d499c5.
If for some reason we are unable to shut it down in orderly fashion
(kernel is stuck holding a lock or similar), then hardware TSHUT will
reset it.
If the temperature is over 95C over a period of time the thermal shutdown
of the tsadc is invoked with can either reset the entire chip via the CRU,
or notify the PMIC via a GPIO. This should be set in the specific board.
Signed-off-by: Caesar Wang <caesar.wang@rock-chips.com>
Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Stock firmware on rk3288 does not initizalize the CNTVOFF registers
of the architected timer correctly. This introduces issues with the
newly added SMP support for rk3288, resulting in rcu stalls due to
differing timer values per core.
There exist preliminary and tested patches for u-boot for this problem,
but there are a minority of boards using other bootloaders like coreboot.
There also is currently a second solution for miss-initialized architected
timers in the works:
- clocksource: arch_timer: Fix code to use physical timers when requested
- clocksource: arch_timer: Allow the device tree to specify uninitialized timer registers
Therefore disable smp on rk3288 again till these are finalized, also
allowing coreboot-based boards to boot again.
Add device nodes for the VOP iommus.
Device nodes for other iommus will be added in later patches.
The iommu nodes use the #iommu-cells property as described in:
Documentation/devicetree/bindings/iommu/iommu.txt
Signed-off-by: Simon Xue <xxm@rock-chips.com>
This patch add reset for CPU nodes to use the reset controller.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
This patch add intmem node des which is needed by platsmp.c
This patch add pmu reference and enable-method for smp
Now that SPI DMA has been fixed on rk3288 we can enable it.
Signed-off-by: Doug Anderson <dianders@chromium.org>
We need to initialize PLL rate and some of bus clock rate while
kernel init, for there is no other module will do that.
Basically on rk3288 we use GPLL for cpu bus, peripheral bus and
most of peripheral clock, CPLL for devices who require 50M/200M
clock rate, leave NPLL behind for special requirement from
display system.
The common-clock-framework will help us to select best source for
child clocks after we init the PLLs propriety.
Add basic OPP entries for current supported Rockchip SoCs.
The operating points are currently very conservative, so individual
boards may opt to redefine them.
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Add dt for rk3288 i2s controller, since i2s clock pins and data pins
default to be GPIO, this patch also add pinctrl to mux them.
Tested on RK3288 board.
Signed-off-by: Jianqun Xu <jay.xu@rock-chips.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into next/dt
Merge "second bunch of dts changes for 3.18" from Heiko Stubner:
More peripheral support for Rockchip SoCs
- dwc2 usb controllers
- spi controllers
- emmc controller
* tag 'v3.18-rockchip-dts2-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
ARM: dts: rockchip: Remove "regulator-always-on" in vcc_rmii for Radxa Rock
ARM: dts: rockchip: fix rk3188 emmc pull references
ARM: dts: rockchip: fix swapped Radxa Rock pinctrl references
ARM: dts: rockchip: clean up rk3xxx mmc nodes
ARM: dts: rockchip: add emmc nodes for rk3066 and rk3188
ARM: dts: rockchip: add Cortex-A9 SPI controller nodes
ARM: dts: rockchip: enable usb ports on Radxa Rock
ARM: dts: rockchip: add dwc2 controllers for rk3066 and rk3188
ARM: dts: rockchip: remove rockchip,bus-index from rk3xxx i2c0
ARM: dts: Switch i2c0 to 400kHz on rk3288-evb-rk808
ARM: dts: Add rk808 PMIC to rk3288-evb-rk808
ARM: dts: Add mshc aliases for rk3288
ARM: dts: Add SPI nodes to rk3288
ARM: dts: Enable USB host1(dwc) on rk3288-evb
ARM: dts: add rk3288 dwc2 controller support
ARM: dts: Add sdio0 and sdio1 to the rk3288
It's convenient (and less confusing to people reading logs) if the
eMMC port on rk3288 is consistenly marked with mmc0 and the sdmmc port
on rk3288 is consistently marked with mmc1. Add the appropriate
aliases.
Reviewed-by: Sonny Rao <sonnyrao@chromium.org>
This adds basic SPI nodes to the base rk3288 device tree file.
A few notes:
* It's assumed that most users of the SPI ports are using chip select
0. Thus the default pinctrl for the ports enables chip select 0
(but not chip select 1 on ports that have it). If a board wants to
use chip select 1 or wants a GPIO chip select the board should
override the pinctrl (just like boards can override UART pinctrl if
they have hardware flow control).
* Since SPI DMA support appears broken and the SPI works fine without
DMA we don't include the DMA references. That can come in a later
change.
Signed-off-by: huang lin <hl@rock-chips.com>
rk3288 has two kind of usb controller, this add the dwc2 controller
for otg and host1.
Controller can works with usb PHY default setting and Vbus on.
Pull "rockchip dma support" from Heiko Stuebner:
Enable the AMBA bus and add necessary dma-controller dts nodes
* tag 'v3.18-rockchip-dma' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
ARM: dts: rockchip: add rk3066 and rk3188 dma controllers
ARM: dts: rockchip: add rk3288 dma controllers
ARM: rockchip: enable the AMBA bus
This patch requires that <https://patchwork.kernel.org/patch/4701721/>
land in order to compile.
Add both the bus and peripheral pl330 dma controllers present in rk3288 socs.
The first dma controller can change between secure and non-secure mode. Both
instances are added but the non-secure variant is left disabled by default,
as on the majority of boards the bootloader leaves it in secure mode.
Tested-by: Kever Yang <kever.yang@rock-chips.com>
Add the core device nodes for the SARADC found on both the Cortex-A9 series
(rk3066 and rk3188) as well as the newer rk3288.
This adds the PWM info (other than the VOP PWM) to the main rk3288
dtsi file.
This adds support for the sdmmc and emmc ports on the rk3288.
The EHCI and HSIC device tree nodes were added in the wrong place.
Fix them.
rk3288 has two kind of usb controller; this adds the ehci variant for
host0 and hsic.
At the moment we don't add any phys for these controllers, but the
default settings seem to work OK.
There is a hardware problem in ohci controller which make it
unavailable and host0 controller can only support high-speed devices.
Node definitions shared by all rk3288 based boards.
Tested-by: Will Deacon <will.deacon@arm.com>
