path: root/arch/arm/boot/dts/rk3xxx.dtsi
2014-05-10ARM: dts: rockchip: convert pinctrl nodes to new bindingsHeiko Stuebner
Introduce the grf syscon and convert the pinctrl drivers for rk3066 and rk3188 to use it, instead of mapping the grf registers themselfs. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Max Schwarz <max.schwarz@online.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2014-03-01ARM: rockchip: add power-management-unitHeiko Stuebner
The pmu is needed to bring up the cores during smp operations and later also other system parts. Therefore add a node and documentation for it. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Ulrich Prinz <ulrich.prinz@googlemail.com>
2014-03-01ARM: rockchip: add snoop-control-unitHeiko Stuebner
This adds the device-node and config select to enable the scu in all Rockchip Cortex-A9 SoCs. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Ulrich Prinz <ulrich.prinz@googlemail.com>
2013-10-14ARM: rockchip: enable arm-global-timerHeiko Stuebner
RK2928 and RK3066 contain a dw_apb timer component, while the rk3188 uses a slightly similar but still different timer component. But all of them support the ARM-global-timer that got added as clocksource driver recently. So enable support for it to get a working clocksource for rk3188. Signed-off-by: Heiko Stuebner <heiko@sntech.de>
2013-10-14ARM: rockchip: move shared dt properties to common source fileHeiko Stuebner
The rk3188 SoC shares a lot of peripherals with the rk3066 SoC, but not all. Therefore move the common parts to a shared dtsi. Signed-off-by: Heiko Stuebner <heiko@sntech.de>
