[ Upstream commit efc2e0bd9594060915696a418564aefd0270b1d6 ]
It is not correct to assign the 24MHz clock oscillator to the GPIO
ports.
Fix it by assigning the proper GPIO clocks instead.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Tested-by: Fabio Berton <fabio.berton@ossystems.com.br>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[ Upstream commit c955b7aec510145129ca7aaea6ecbf6d748f5ebf ]
According to the Rockchip vendor tree the PMU interrupt number is
76, so fix it accordingly.
This patch adds usb otg/host controllers and phys nodes for RV1108 SoCs.
Signed-off-by: Frank Wang <frank.wang@rock-chips.com>
Add cpu opp table for rv1108 to support frequency
from 408MHZ to 1008MHZ.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Add pwm device tree node for rv1108 soc
Add SPI device tree node for rv1108.
Add saradc device tree node for rv1108 soc
Add watchdog device tree node for rv1108
There are four i2c controllers on rv1108, add
device tree node for them.
Somehow the strange property ordering of the rv1108 mmc nodes slipped
through when it was added. To lessen the confusion in the future, do
the needed reordering to bring them in line with our regular order.
Enable sdmmc on rv1108 evaluation board. Also
add pinctrl for sdmmc controller.
rv1108
"clock-freq-min-max" was deprecated. There is only using in rv1108.dtsi.
Use the "max-frequency" for removiing "clock-freq-min-max" in future.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Rockchip finally named the SOC as RV1108, so change it
for compatible.
[adapt include in rk1108-evb.dts to not introduce errors]
