Rockchip SoCs use 2 different numbering schemes. Where the gpio-
controllers just count 0-31 for their 32 gpios, the underlying
iomux controller splits these into 4 separate entities A-D.
Device-schematics always use these iomux-values to identify pins,
so to make mapping schematics to devicetree easier Andy Yan introduced
named constants for the pins but so far we only used them on new
additions.
Using a sed-script created by Emil Renner Berthing bulk-convert
the remaining raw gpio numbers into their descriptive counterparts
and also gets rid of the unhelpful RK_FUNC_x -> x and RK_GPIOx -> x
mappings:
/rockchip,pins *=/bcheck
b # to end of script
:append-next-line
N
:check
/^[^;]*$/bappend-next-line
s/<RK_GPIO\([0-9]\) /<\1 /g
s/<\([^ ][^ ]* *\)0 /<\1RK_PA0 /g
s/<\([^ ][^ ]* *\)1 /<\1RK_PA1 /g
s/<\([^ ][^ ]* *\)2 /<\1RK_PA2 /g
s/<\([^ ][^ ]* *\)3 /<\1RK_PA3 /g
s/<\([^ ][^ ]* *\)4 /<\1RK_PA4 /g
s/<\([^ ][^ ]* *\)5 /<\1RK_PA5 /g
s/<\([^ ][^ ]* *\)6 /<\1RK_PA6 /g
s/<\([^ ][^ ]* *\)7 /<\1RK_PA7 /g
s/<\([^ ][^ ]* *\)8 /<\1RK_PB0 /g
s/<\([^ ][^ ]* *\)9 /<\1RK_PB1 /g
s/<\([^ ][^ ]* *\)10 /<\1RK_PB2 /g
s/<\([^ ][^ ]* *\)11 /<\1RK_PB3 /g
s/<\([^ ][^ ]* *\)12 /<\1RK_PB4 /g
s/<\([^ ][^ ]* *\)13 /<\1RK_PB5 /g
s/<\([^ ][^ ]* *\)14 /<\1RK_PB6 /g
s/<\([^ ][^ ]* *\)15 /<\1RK_PB7 /g
s/<\([^ ][^ ]* *\)16 /<\1RK_PC0 /g
s/<\([^ ][^ ]* *\)17 /<\1RK_PC1 /g
s/<\([^ ][^ ]* *\)18 /<\1RK_PC2 /g
s/<\([^ ][^ ]* *\)19 /<\1RK_PC3 /g
s/<\([^ ][^ ]* *\)20 /<\1RK_PC4 /g
s/<\([^ ][^ ]* *\)21 /<\1RK_PC5 /g
s/<\([^ ][^ ]* *\)22 /<\1RK_PC6 /g
s/<\([^ ][^ ]* *\)23 /<\1RK_PC7 /g
s/<\([^ ][^ ]* *\)24 /<\1RK_PD0 /g
s/<\([^ ][^ ]* *\)25 /<\1RK_PD1 /g
s/<\([^ ][^ ]* *\)26 /<\1RK_PD2 /g
s/<\([^ ][^ ]* *\)27 /<\1RK_PD3 /g
s/<\([^ ][^ ]* *\)28 /<\1RK_PD4 /g
s/<\([^ ][^ ]* *\)29 /<\1RK_PD5 /g
s/<\([^ ][^ ]* *\)30 /<\1RK_PD6 /g
s/<\([^ ][^ ]* *\)31 /<\1RK_PD7 /g
s/<\([^ ][^ ]* *[^ ][^ ]* *\)0 /<\1RK_FUNC_GPIO /g
s/<\([^ ][^ ]* *[^ ][^ ]* *\)RK_FUNC_\([1-9]\) /<\1\2 /g
Suggested-by: Emil Renner Berthing <esmil@mailme.dk>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Add the pin settings for the SPI pins so they can be used across
multiple boards.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Pass the 'dma-names' property to the SPI ports so that DMA can
be supported.
Add support for the internal timer peripheral on RV1108.
Pass the 'dmas' property to the UART ports so that DMA can
be supported.
Tested-by: Fabio Berton <fabio.berton@ossystems.com.br>
It is not correct to assign the 24MHz clock oscillator to the GPIO
ports.
Fix it by assigning the proper GPIO clocks instead.
According to the Rockchip vendor tree the PMU interrupt number is
76, so fix it accordingly.
on rv1108
Since firmware does not initialize any of the generic timer CPU
registers pass the 'arm,cpu-registers-not-fw-configured' property as
suggested in Documentation/devicetree/bindings/timer/arm,arch_timer.txt.
This also aligns with other Rockchip SoC dtsi files.
Like it is done on cpu nodes of other Rockchip SoCs, pass the
'clock-latency' property to the CPU node, so that cpufreq driver
can take the latency into account when switching frequencies.
Add GMAC support for RV1108.
Add the pin settings for the emmc pins so they can be used across multiple
boards.
Update all 32bit rockchip devicetree files to use SPDX-License-Identifiers.
All files except rk3288-veyron-analog-audio.dtsi (which is GPL 2.0 only)
claim to be GPL and X11 while the actual license text is MIT. Use the
MIT SPDX tag for them.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Acked-by: Brian Norris <briannorris@chromium.org>
Acked-by: Matthias Brugger <mbrugger@suse.com>
Acked-by: Douglas Anderson <dianders@chromium.org>
Add thermal zone and dynamic CPU power coefficients for RV1108
Signed-off-by: Rocky Hao <rocky.hao@rock-chips.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Add tsadc needed main information for RV1108 SoC.
750000Hz is the max clock rate supported by tsadc module.
This patch adds usb otg/host controllers and phys nodes for RV1108 SoCs.
Signed-off-by: Frank Wang <frank.wang@rock-chips.com>
Add cpu opp table for rv1108 to support frequency
from 408MHZ to 1008MHZ.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Add pwm device tree node for rv1108 soc
Add SPI device tree node for rv1108.
Add saradc device tree node for rv1108 soc
Add watchdog device tree node for rv1108
There are four i2c controllers on rv1108, add
device tree node for them.
Somehow the strange property ordering of the rv1108 mmc nodes slipped
through when it was added. To lessen the confusion in the future, do
the needed reordering to bring them in line with our regular order.
Enable sdmmc on rv1108 evaluation board. Also
add pinctrl for sdmmc controller.
rv1108
"clock-freq-min-max" was deprecated. There is only using in rv1108.dtsi.
Use the "max-frequency" for removiing "clock-freq-min-max" in future.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Rockchip finally named the SOC as RV1108, so change it
for compatible.
[adapt include in rk1108-evb.dts to not introduce errors]
