path: root/arch/arm/boot/dts/s3c64xx.dtsi
2017-03-21ARM: dts: s3c64xx: Fix infinite interrupt in soft modeKrzysztof Kozlowski
In soft (no-reboot) mode, the driver self-pings watchdog upon expiration of an interrupt. The interrupt has to be cleared, because otherwise system enters infinite interrupt handling loop. Use a samsung,s3c6410-wdt compatible to select appropriate quirk for clearing the watchdog interrupt. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
2017-03-13ARM: dts: s3c64xx: Enable watchdog on all S3C64xx boardsKrzysztof Kozlowski
Watchdog module does not have external dependencies so it can be safely enabled in s3c64xx.dtsi thus making it available for all S3C64xx-based boards. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Guenter Roeck <linux@roeck-us.net>
2014-10-21ARM: dts: Enable PWM node by default for s3c64xxTomasz Figa
The PWM block is required for system clock source so it must be always enabled. This patch fixes boot issues on SMDK6410 which did not have the node enabled explicitly for other purposes. Fixes: eeb93d02 ("clocksource: of: Respect device tree node status") Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-09ARM: dts: SAMSUNG: Add aliases of UART nodesTomasz Figa
This patch adds alias entries for UART nodes of all SoCs using samsung-uart compatible UART controllers, so that the dependency on probe order is removed and deterministic device naming is assured. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17ARM: dts: Add basic dts include files for Samsung S3C64xx SoCsTomasz Figa
This patch adds basic device tree definitions for Samsung S3C64xx SoCs. Since all the SoCs in the series are very similar, the files are created hierarchically - one file for the whole series and then separate files for particular SoCs including the common one. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
