path: root/arch/arm/boot/dts/s5pv210-aries.dtsi
2020-06-22ARM: dts: s5pv210: Set keep-power-in-suspend for SDHCI1 on AriesJonathan Bakker
commit 869d42e6eba821905e1a0950623aadafe1a6e6d3 upstream. SDHCI1 is connected to a BCM4329 WiFi/BT chip which requires power to be kept over suspend. As the surrounding hardware supports this, mark it as such. This fixes WiFi after a suspend/resume cycle. Fixes: 170642468a51 ("ARM: dts: s5pv210: Add initial DTS for Samsung Aries based phones") Cc: <stable@vger.kernel.org> Signed-off-by: Jonathan Bakker <xc-racer2@live.ca> Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-01-10ARM: dts: s5pv210: Add support for more devices present on AriesJonathan Bakker
This commit enables following devices present on Aries based phones: - pwm-vibrator attached to PWM 1 - poweroff support - Atmel maXTouch touchscreen, connected to I2C-2 - Broadcom BCM4329 Bluetooth over UART-0 Signed-off-by: Jonathan Bakker <xc-racer2@live.ca> Signed-off-by: Paweł Chmiel <pawel.mikolaj.chmiel@gmail.com> Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
2019-01-10ARM: dts: s5pv210: Add reserved memory for MFC on AriesPaweł Chmiel
THis commit adds memory reservation required by MFC (Multi Format Codec) to run. On S5PV210 both regions needs to be on separate memory banks. Size of both regions is taken from vendor Linux kernel sources. Signed-off-by: Paweł Chmiel <pawel.mikolaj.chmiel@gmail.com> Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
2018-07-07ARM: dts: s5pv210: Add initial DTS for Samsung Aries based phonesPaweł Chmiel
This DTS file have initial support Samsung Aries based phones. Initial version have support for: - sdcard - internal memory (present only on non 4g variant) - max8998 pmic and rtc - max17040 fuel gauge - gpio keys - fimd (no panel driver yet) - usb (peripherial mode) - wifi Signed-off-by: Paweł Chmiel <pawel.mikolaj.chmiel@gmail.com> Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
