commit ee0aa926ddb0bd8ba59e33e3803b3b5804e3f5da upstream.
Currently the maximum rate for peripheral clock is calculated based on a
typical 133MHz MCK. The maximum frequency is defined in the datasheet as a
ratio to MCK. Some sama5d3 platforms are using a 166MHz MCK. Update the
device trees to match the maximum rate based on 166MHz.
Reported-by: Karl Rudbæk Olsen <karl@micro-technic.com>
Fixes: d2e8190b7916 ("ARM: at91/dt: define sama5d3 clocks")
Link: https://lore.kernel.org/r/20200110172007.1253659-1-alexandre.belloni@bootlin.com
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
git://git.kernel.org/pub/scm/linux/kernel/git/at91/linux into arm/dt
AT91 DT for 5.3
- switch to new sckc bindings
- convert soc bindings to json-schema
* tag 'at91-5.3-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/at91/linux:
dt-bindings: arm: Convert Atmel board/soc bindings to json-schema
ARM: dts: at91: sama5d3: switch to new sckc bindings
ARM: dts: at91: at91sam9rl: switch to new sckc bindings
ARM: dts: at91: at91sam9g45: switch to new sckc bindings
ARM: dts: at91: at91sam9x5: switch to new sckc bindings
ARM: dts: at91sam9261ek: remove unused chosen nodes
Remove the child nodes of the sckc as they are not necessary anymore.
Also, switch to the new atmel,sama5d3-sckc compatible string to use the
proper startup time for the RC oscillator (500 µs instead of 75).
Based on 1 normalized pattern(s):
licensed under gplv2 or later
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 118 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190519154040.961286471@linutronix.de
Remove the usage of skeleton.dtsi in the remaining dts files. It was
deprecated since commit 9c0da3cc61f1 ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"). This will make adding a unit-address to
memory nodes easier.
The main tricky part to removing skeleton.dtsi is we could end up with
no /memory node at all when a bootloader depends on one being present. I
hacked up dtc to check for this condition.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Antoine Tenart <antoine.tenart@bootlin.com>
Acked-by: Alexandre TORGUE <alexandre.torgue@st.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Tested-by: Kevin Hilman <khilman@baylibre.com>
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Reviewed-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Tested-by: Gregory CLEMENT <gregory.clement@bootlin.com>
This adds labels to commonly used device-tree nodes so that derivative
boards can avoid ahb/apb hierarchy.
Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com>
Remove pullup on uart TX signals, they are push-pull outputs thus
pullups are pointless.
Add pullup on uart RX signals, they prevent the RX signals to be left
floating and so consuming a useless extra amount of power in crowbarred
state if nothing is connected to RX.
Signed-off-by: Peter Rosin <peda@axentia.se>
Add simple-mfd and syscon to the TC blocks to allow to register one of the
channels as clocksource properly at boot time and free up the remaining
channels for other use.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
the following command:
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Declare new nodes for the EBI and NAND controllers embedded in various
at91/sama5 SoCs.
Remove pullup on dbgu DTXD signal, it is a push-pull output thus the
pullup is pointless.
Add pullup on dbgu DRXD signal, it prevents the DRXD signal to be left
state if nothing is externally connected to dbgu.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
Endpoint nodes have a reg property. Add their mandatory unit-address.
This solves:
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep0 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep1 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep2 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep3 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep4 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep5 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep6 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep7 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep8 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep9 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep10 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep11 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep12 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep13 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep14 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep15 has a reg or ranges property, but no unit name
The triggers don't need a reg property, remove it when prenset. Also remove
the unit-address from their name.
This solves:
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@3 has a unit name, but no reg property
Add node to support SAMA5D3 hardware random number generator.
Signed-off-by: Mike Williams <mike@mikebwilliams.com>
[nicolas.ferre@atmel.com: reduce the register map size]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The PMC is not only used to drive the clocks but also has some registers
related to other functions. One of those is for example the USB gadget
bias.
Using a syscon allows to properly separate those functions.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
The watchdog, the reset controller, the RTC, the shutdown controller, the
timer counters and the LCD PWM need the slow clock, add it where necessary.
[boris.brezillon@free-electrons.com: add tcb clocks]
They'll use "atmel,sama5d3-rstc" for reset function.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
[nicolas.ferre@atmel.com: add the old compatible string as a fallback]
at91sam9g45, at91sam9x5 and sama5 SoCs should not use
"atmel,at91sam9rl-udc" for their USB device compatible property since
this compatible is attached to a specific hardware bug fix.
Tested-by: Bo Shen <voice.shen@atmel.com>
Cc: <stable@vger.kernel.org> #4.0+
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The ohci driver now calls clk_set_rate on the uhpck clock (which forwards
set_rate requests to its parent: the usb clock).
Remove useless references to usb clocks from ohci definitions.
The uhpck is useless for High-Speed communications, remove the reference
to this clock in all ehci definitions.
commit 111573ccd89b ("mtd: atmel_nand: check NFC busy flag by HSMC_SR
instead of NFC cmd regs")
check NFC busy by nfc SR instead of NFC cmd regs. So we don't need to
map NFC cmd registers to include NFCBUSY bit.
That means we only need map 0x08000000 instead of 0x10000000 for NFC
cmd regs.
This patch reduce the NFC cmd regs map for sama5d3 & sama5d4.
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Merge "wireless wl12xx and omap device tree changes for v4.1" from Tony
Lindgren:
Wireless and omap changes to make wl12xx driver to use device tree
data instead of platform data from Eliad Peller <eliad@wizery.com>:
- Add device-tree support to the wlcore (wl12xx/wl18xx) driver.
- Update the current users to use the bindings instead of pdata-quirks.
- Finally, remove the deprecated wl12xx_platform_data struct
Note that da850 board file code that still uses the platform data,
but we have da850.dtsi that can be used instead. So it was decided
that we should try to remove the wl12xx support from the da850
board file as suggested by Sekhar Nori <nsekhar@ti.com>. As it's
the last patch in the series, the last patch can be simply reverted
if needed.
As this series touches quite a bit of arch code, it was suggested
by Kalle Valo <kvalo@codeaurora.org> that the whole series should
be merged via the arm-soc tree.
* tag 'omap-for-v4.1/wl12xx-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
wlcore: remove wl12xx_platform_data
ARM: dts: add wl12xx/wl18xx bindings
wlcore: add device-tree support
dt: bindings: add TI's wilink wireless device
wl12xx: use frequency instead of enumerations for pdata clocks
wlcore: set irq_trigger in board files instead of hiding behind a quirk
+ Linux 4.0-rc4
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
The DBGU is not a simple UART and we need to be able to distinguish it from the
other UARTs, in particular to get its address and check the chip id.
The UTMI clock must be selected by any high-speed USB IP. The logic behind it
needs this particular clock.
So, correct the clock in the device tree files affected.
Reported-by: Bo Shen <voice.shen@atmel.com>
Cc: <stable@vger.kernel.org> #3.18
Since turning on idle-halt in commit fe46aa679f12 (ARM: at91/dt: add
sam9 watchdog default options to SoCs), SoCs compatible with at91sam9260-wdt
no longer reboot if the watchdog times out while the CPU is in idle state.
Removing the 'idle-halt' flag that was set by default fixes this.
Signed-off-by: Michel Marti <mma@objectxp.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
[nicolas.ferre@atmel.com: rework the commit message]
According to v4l2 dt document, we add:
a camera host: ISI port.
a i2c camera sensor: ov2640 port.
to sama5d3xmb.dtsi.
The ov2640 node defines the pinctrls, clocks and refer to isi port.
The ISI node also has a reference to the ov2640 port.
The mck is decided by the board design, move it to mb related
dtsi file.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
The ISI has 12 data lines, add the missing two data lines.
As the ISI has 12 data lines, however we only use 8 data lines with
sensor module. So, split the data line into two groups which make
it can be choosed depends on the hardware design.
Add ISI peripheral clock in sama5d3.dtsi.
Add nodes for the SRAM available on atmel SoCs
For the at91sam9260 and the at91sam9g20, address mirroring is used to create a
single contiguous SRAM range instead of declaring two separate banks.
Also remove leftover TODOs in the sam9g45 file
[nicolas.ferre@atmel.com: correct at91sam9rl sram size => 0x10000]
The sama5d3 has Special Function Registers that allow to manage OHCI, EBI and
the UTMI clock.
[nicolas.ferre@atmel.com: reg size: 0x60]
This switches the SAMA5D3 to use the new atmel,sama5d3-pinctrl id that was
added with the drive strength options patch.
Signed-off-by: Marek Roszko <mark.roszko@gmail.com>
[nicolas.ferre@atmel.com: second compatible string kept as at91sam9x5]
The atmel_nand driver is now able to handle the nfc clock, add it to sama5d3.
Add the DMA configuration for USARTs mainly because it is not obvious to
add the FIFO flag which is needed for rx.
git://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux
Pull AT91 ramc and reset/poweroff related DT patches from Maxim Ripard:
"This branch gathers a few devicetree patches needed for the reworks found in
the later patches to be sent. More precisely, it holds:
- The addition of ddrck for the sama5d3 and the sam9 SoCs
- The addition of the shutdown controller node in the sama5d3 DTSI
- The slight rework of the ramc bindings for the SoCs that have several RAM
controllers"
arch/arm/boot/dts/at91sam9g45.dtsi
The SAMA5D3 has a shutdown controller identical to the sam9x5 SoC family.
Declare it in the DT.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Define the available clock for mprddr and take both mpddr_clk and ddrck in the
ram controller driver.
Having clocks grouped in a subnode is common practice, so move the crystals
under a clocks node for the sama5d3 SoC and sama5d3 based boards.
Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
3.16 third DT series:
- move of both at91sam9n12 and at91sam9x5 to CCF
* tag 'at91-dt3' of git://github.com/at91linux/linux-at91:
ARM: at91: move sam9n12 SoC to the CCF
ARM: at91/dt: define sam9n12ek crystal frequencies
ARM: at91/dt: define sam9n12 clocks
ARM: at91: prepare common clk transition for sam9n12 SoC
ARM: at91: move sam9x5 SoCs to the CCF
ARM: at91/dt: define sam9x5ek's crystal frequencies
ARM: at91/dt: define sam9x5 clocks
ARM: at91: prepare common clk transition for sam9x5 SoCs
dt-bindings: clock: Move at91.h to dt-bindigs/clock
ARM: at91: fix spi cs on sama5d3 Xplained board
arch/arm/boot/dts/at91sam9rl.dtsi
Needed as a dependency for the at91/dt2 branch
Replace the old main and clk definitions (fixed rate clk) by the new main and
slow clk subtree definition (ck = mux(rc_osc, osc)).
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Most of the clock related dt-binding header files are located in
dt-bindings/clock folder. It would be good to keep all the similar
header files at a single location.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
CC: Rob Landley <rob@landley.net>
CC: Andrew Victor <linux@maxim.org.za>
CC: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Acked-by: Boris BREZILLON <b.brezillon.dev@gmail.com>
[nicolas.ferre@atmel.com: add new at91sam9261 & at91sam9rl]
