Separate the definitions for the emac and the gmac in different files and
include them in the final board dts that uses them.
Solves:
Warning (unit_address_vs_reg): Node /ahb/apb/ethernet@f0028000 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/ethernet@f802c000 has a unit name, but no reg property
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
This patch splits the sama5d3 SoCs definition:
- a common base for all sama5d3 SoCs (sama5d3.dtsi)
- several optional peripheral definitions which will be included by sama5d3
specific SoCs (sama5d3_'periph name'.dtsi)
- sama5d3 specific SoC definitions (sama5d3x.dtsi)
This provides a better representation of the real hardware (drop unneed
dt nodes) and avoids peripheral id conflict (which is not the case for
current sama5d3 SoCs, but could be if other SoCs of this family are
released).
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
[nicolas.ferre@atmel.com: add more "sama5d3?" compatibility strings]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
to prepare the switch to the macro.
Add device tree files for the SAMA5D3 family (SAMA5D31, SAMA5D33, SAMA5D34 and
SAMA5D35).
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
