path: root/arch/arm/boot/dts/sama5d31ek.dts
2013-10-16ARM: at91/dt: split sama5d3 peripheral definitionsBoris BREZILLON
This patch splits the sama5d3 SoCs definition: - a common base for all sama5d3 SoCs (sama5d3.dtsi) - several optional peripheral definitions which will be included by sama5d3 specific SoCs (sama5d3_'periph name'.dtsi) - sama5d3 specific SoC definitions (sama5d3x.dtsi) This provides a better representation of the real hardware (drop unneed dt nodes) and avoids peripheral id conflict (which is not the case for current sama5d3 SoCs, but could be if other SoCs of this family are released). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> [nicolas.ferre@atmel.com: add more "sama5d3?" compatibility strings] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-26ARM: at91: dt: add device tree files for SAMA5D3 familyLudovic Desroches
Add device tree files for the SAMA5D3 family (SAMA5D31, SAMA5D33, SAMA5D34 and SAMA5D35). Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
