path: root/arch/arm/boot/dts/sama5d36ek_cmp.dts
2019-04-08ARM: dts: atmel boards: use SPDX-License-IdentifierAlexandre Belloni
External E-Mail The X11 license text [1] is explicitly for the X Consortium and has a couple of extra clauses. The MIT license text [2] is actually what the current DT files claim. [1] https://spdx.org/licenses/X11.html [2] https://spdx.org/licenses/MIT.html Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
2017-01-10ARM: dts: at91: add dts file for sama5d36ek CMP boardWenyou Yang
The sama5d36ek CMP board is the variant of sama5d3xek board. It is equipped with the low-power DDR2 SDRAM, PMIC ACT8865 and some power rail. Its main purpose is used to measure the power consumption. The difference of the sama5d36ek CMP dts from sama5d36ek dts is listed as below. 1. The USB host nodes are removed, that is, the USB host is disabled. 2. The gpio_keys node is added to wake up from the sleep. 3. The LCD isn't supported due to the pins for LCD are conflicted with gpio_keys. 4. The adc0 node support the pinctrl sleep state to fix the over consumption on VDDANA. As said in errata, "When the USB host ports are used in high speed mode (EHCI), it is not possible to suspend the ports if no device is attached on each port. This leads to increased power consumption even if the system is in a low power mode." That is why the the USB host is disabled. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
