[ Upstream commit 321cc359d899a8e988f3725d87c18a628e1cc624 ]
We need this new compatibility string as we experienced different behavior
for this 10/100Mbits/s macb interface on this particular SoC.
Backward compatibility is preserved as we keep the alternative strings.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
Some at91 SoCs embed a 10/100 Mbit Ethernet IP, that is based on the
at91sam9260 SoC.
Fix at91 DTs accordingly.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
File name had at91 prefix, which is not the case anymore for SAMA5D3.
AT91SAM9x5 was mentioned instead of SAMA5D3 SoC.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Define sama5d3 clocks in sama5d3 device tree.
Add references to the appropriate clocks in each peripheral.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
This patch splits the sama5d3 SoCs definition:
- a common base for all sama5d3 SoCs (sama5d3.dtsi)
- several optional peripheral definitions which will be included by sama5d3
specific SoCs (sama5d3_'periph name'.dtsi)
- sama5d3 specific SoC definitions (sama5d3x.dtsi)
This provides a better representation of the real hardware (drop unneed
dt nodes) and avoids peripheral id conflict (which is not the case for
current sama5d3 SoCs, but could be if other SoCs of this family are
released).
[nicolas.ferre@atmel.com: add more "sama5d3?" compatibility strings]
