path: root/arch/arm/boot/dts/sama5d3_gmac.dtsi
2015-03-04ARM: at91/dt/trivial: correct file headers for SAMA5D3 SoC peripheralsNicolas Ferre
File name had at91 prefix, which is not the case anymore for SAMA5D3. AT91SAM9x5 was mentioned instead of SAMA5D3 SoC. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-07-24ARM: at91: change compatibility string for sama5d3x gemCyrille Pitchen
this new compatibility string prevents macb/gem driver from using the scatter-gather and gso features on sama5d3x boards. Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-02ARM: at91/dt: define sama5d3 clocksBoris BREZILLON
Define sama5d3 clocks in sama5d3 device tree. Add references to the appropriate clocks in each peripheral. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-10-16ARM: at91/dt: split sama5d3 peripheral definitionsBoris BREZILLON
This patch splits the sama5d3 SoCs definition: - a common base for all sama5d3 SoCs (sama5d3.dtsi) - several optional peripheral definitions which will be included by sama5d3 specific SoCs (sama5d3_'periph name'.dtsi) - sama5d3 specific SoC definitions (sama5d3x.dtsi) This provides a better representation of the real hardware (drop unneed dt nodes) and avoids peripheral id conflict (which is not the case for current sama5d3 SoCs, but could be if other SoCs of this family are released). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> [nicolas.ferre@atmel.com: add more "sama5d3?" compatibility strings] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
