path: root/arch/arm/boot/dts/sama5d3_mci2.dtsi
2014-04-18dt-bindings: clock: Move at91.h to dt-bindigs/clockTushar Behera
Most of the clock related dt-binding header files are located in dt-bindings/clock folder. It would be good to keep all the similar header files at a single location. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> CC: Rob Landley <rob@landley.net> CC: Andrew Victor <linux@maxim.org.za> CC: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Acked-by: Boris BREZILLON <b.brezillon.dev@gmail.com> [nicolas.ferre@atmel.com: add new at91sam9261 & at91sam9rl] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02ARM: at91/dt: define sama5d3 clocksBoris BREZILLON
Define sama5d3 clocks in sama5d3 device tree. Add references to the appropriate clocks in each peripheral. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-10-16ARM: at91/dt: split sama5d3 peripheral definitionsBoris BREZILLON
This patch splits the sama5d3 SoCs definition: - a common base for all sama5d3 SoCs (sama5d3.dtsi) - several optional peripheral definitions which will be included by sama5d3 specific SoCs (sama5d3_'periph name'.dtsi) - sama5d3 specific SoC definitions (sama5d3x.dtsi) This provides a better representation of the real hardware (drop unneed dt nodes) and avoids peripheral id conflict (which is not the case for current sama5d3 SoCs, but could be if other SoCs of this family are released). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> [nicolas.ferre@atmel.com: add more "sama5d3?" compatibility strings] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
