The watchdog, the reset controller, the RTC, the shutdown controller, the
timer counters and the LCD PWM need the slow clock, add it where necessary.
[boris.brezillon@free-electrons.com: add tcb clocks]
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
File name had at91 prefix, which is not the case anymore for SAMA5D3.
AT91SAM9x5 was mentioned instead of SAMA5D3 SoC.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Most of the clock related dt-binding header files are located in
dt-bindings/clock folder. It would be good to keep all the similar
header files at a single location.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
CC: Rob Landley <rob@landley.net>
CC: Andrew Victor <linux@maxim.org.za>
CC: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Acked-by: Boris BREZILLON <b.brezillon.dev@gmail.com>
[nicolas.ferre@atmel.com: add new at91sam9261 & at91sam9rl]
Define sama5d3 clocks in sama5d3 device tree.
Add references to the appropriate clocks in each peripheral.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
This patch splits the sama5d3 SoCs definition:
- a common base for all sama5d3 SoCs (sama5d3.dtsi)
- several optional peripheral definitions which will be included by sama5d3
specific SoCs (sama5d3_'periph name'.dtsi)
- sama5d3 specific SoC definitions (sama5d3x.dtsi)
This provides a better representation of the real hardware (drop unneed
dt nodes) and avoids peripheral id conflict (which is not the case for
current sama5d3 SoCs, but could be if other SoCs of this family are
released).
[nicolas.ferre@atmel.com: add more "sama5d3?" compatibility strings]
