path: root/arch/arm/boot/dts/sama5d3xcm.dtsi
2017-05-31ARM: dts: at91: Add the NOR flash available on sama5d3 dev kitsBoris Brezillon
sama5d3 CPU modules embed a parallel NOR flash connected to the EBI bus. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2017-05-31ARM: dts: at91: Switch to the new NAND bindingsBoris Brezillon
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND nodes along the way. Note that we keep using old bindings in at91rm9200.dtsi because this SoC is not supported by the EBI driver. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Tested-by: Peter Rosin <peda@axentia.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-15ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitionsAlexandre Belloni
Separate the definitions for the emac and the gmac in different files and include them in the final board dts that uses them. Solves: Warning (unit_address_vs_reg): Node /ahb/apb/ethernet@f0028000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /ahb/apb/ethernet@f802c000 has a unit name, but no reg property Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-04ARM: at91/dt: sama5d3xek: use stdout-pathAlexandre Belloni
Use stdout-path to specify the console and remove the console argument from the kernel command line. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-05-11ARM: at91/dt: drop deprecated mainck node from pmcGaël PORTAY
The clock-frequency property became obsolete since the rework of the main clock driver in 3.16 (see commit 27cb1c2083373a44130d50d4d2fb64cf7eff2d90). It now get and uses the clock-frequency from the main_xtal node. Signed-off-by: Gaël PORTAY <g.portay@overkiz.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-01-15ARM: at91/dt: sama5d3: enable D2 as the heartbeat LEDJosh Wu
This D2 led is available for all sama5d3x-ek board. So make it a heartbeat LED. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-11-16ARM: at91/dt: Fix sama5d3x typosPeter Rosin
Some DT files had a typo with a missing "5" in sama5d3x first compatible string. Signed-off-by: Peter Rosin <peda@axentia.se> [nicolas.ferre@atmel.com: modify commit log] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-01ARM: at91/dt: describe rgmii ethernet phy connected to sama5d3xek boardsBoris BREZILLON
Add ethernet-phy nodes and specify phy interrupt (connected to pin PB25) and board specific timing configs. Atmel has two different HW designs for its CPU modules: the first one (produced by Embest) is connecting PHYAD[0-2] pins to pull up resistors and the other one (produced by Ronetix) is connecting PHYAD0 to a pull up resistor and PHYAD[1-2] to pull down resistors. As a result, Ronetix design will have its PHY available at address 0x1 and Embest design at 0x7. By defining both phys we're letting the phy core detect the one actually available on the MDIO bus. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-07-09ARM: at91/dt: sama5d3 crystals under the clocks nodeAlexandre Belloni
Having clocks grouped in a subnode is common practice, so move the crystals under a clocks node for the sama5d3 SoC and sama5d3 based boards. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-05-07ARM: at91/dt: add xtal frequencies to sama5d3xcm boardsBoris BREZILLON
Define crystal frequencies of sama5d3xcm boards. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02ARM: at91/dt: remove old clk materialBoris BREZILLON
This patch removes the old main clk node which is now useless as sama5d3 SoCs and boards are no longer compatible with the old at91 clk implementations. It also remove old clock definitions (clock definitions using at91 old clk framework). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02ARM: at91/dt: define sama5d3xek's main clk frequencyBoris BREZILLON
Define the main clock frequency for the new main clock node in sama5d3xcm.dtsi. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-10-16ARM: at91/dt: split sama5d3 peripheral definitionsBoris BREZILLON
This patch splits the sama5d3 SoCs definition: - a common base for all sama5d3 SoCs (sama5d3.dtsi) - several optional peripheral definitions which will be included by sama5d3 specific SoCs (sama5d3_'periph name'.dtsi) - sama5d3 specific SoC definitions (sama5d3x.dtsi) This provides a better representation of the real hardware (drop unneed dt nodes) and avoids peripheral id conflict (which is not the case for current sama5d3 SoCs, but could be if other SoCs of this family are released). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> [nicolas.ferre@atmel.com: add more "sama5d3?" compatibility strings] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-08-23ARM: at91/dt: sama5d3xek: remove the useless NFC dt parametersJosh Wu
The NFC driver code doesn't use atmel,has-nfc and atmel,use-nfc-sram. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2013-05-27Merge tag 'at91-cleanup' of git://github.com/at91linux/linux-at91 into ↵Olof Johansson
next/cleanup From Nicolas Ferre: Big update converting pinctrl to use macros and header files. Increases readability and avoids typos. Update of AT91 defconfigs and merge of defconfigs for the similar SoCs sam9260/9g20 and sam9261/9g10. * tag 'at91-cleanup' of git://github.com/at91linux/linux-at91: ARM: at91: udpate defconfigs ARM: at91: dt: switch to standard IRQ flag defines ARM: at91: dt: switch to pinctrl to pre-processor ARM: at91: dt: add pinctrl pre-processor define ARM: at91: dt: switch to standard GPIO flag defines. ARM: at91: dt: use #include for all device trees Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-14ARM: at91: dts: request only spi cs-gpios used on sama5d3x cpu moduleLudovic Desroches
Instead of requesting all available spi cs-gpios, request only the ones used on the board, in our case on the cpu module. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-26ARM: at91: dt: add device tree files for SAMA5D3 familyLudovic Desroches
Add device tree files for the SAMA5D3 family (SAMA5D31, SAMA5D33, SAMA5D34 and SAMA5D35). Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
