External E-Mail
The X11 license text [1] is explicitly for the X Consortium and has a
couple of extra clauses. The MIT license text [2] is actually what the
current DT files claim.
[1] https://spdx.org/licenses/X11.html
[2] https://spdx.org/licenses/MIT.html
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Improve the DTS files by removing all the leading "0x" and zeros to fix the
following dtc warnings:
Warning (unit_address_format): Node /XXX unit name should not have leading "0x"
and
Warning (unit_address_format): Node /XXX unit name should not have leading 0s
Converted using the following command:
find . -type f \( -iname *.dts -o -iname *.dtsi \) -exec sed -i -e "s/@\([0-9a-fA-FxX\.;:#]+\)\s*{/@\L\1 {/g" -e "s/@0x\(.*\) {/@\1 {/g" -e "s/@0+\(.*\) {/@\1 {/g" {} +^C
For simplicity, two sed expressions were used to solve each warnings separately.
To make the regex expression more robust a few other issues were resolved,
namely setting unit-address to lower case, and adding a whitespace before the
the opening curly brace:
https://elinux.org/Device_Tree_Linux#Linux_conventions
This will solve as a side effect warning:
Warning (simple_bus_reg): Node /XXX@<UPPER> simple-bus unit address format error, expected "<lower>"
This is a follow up to commit 4c9847b7375a ("dt-bindings: Remove leading 0x from bindings notation")
Reported-by: David Daney <ddaney@caviumnetworks.com>
Suggested-by: Rob Herring <robh@kernel.org>
Signed-off-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Signed-off-by: Rob Herring <robh@kernel.org>
The sama5d36ek CMP board is the variant of sama5d3xek board.
It is equipped with the low-power DDR2 SDRAM, PMIC ACT8865 and
some power rail. Its main purpose is used to measure the power
consumption.
The difference of the sama5d36ek CMP dts from sama5d36ek dts is
listed as below.
1. The USB host nodes are removed, that is, the USB host is disabled.
2. The gpio_keys node is added to wake up from the sleep.
3. The LCD isn't supported due to the pins for LCD are conflicted
with gpio_keys.
4. The adc0 node support the pinctrl sleep state to fix the over
consumption on VDDANA.
As said in errata, "When the USB host ports are used in high speed
mode (EHCI), it is not possible to suspend the ports if no device is
attached on each port. This leads to increased power consumption even
if the system is in a low power mode." That is why the the USB host
is disabled.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
