path: root/arch/arm/boot/dts/sama5d3xmb_emac.dtsi
2019-05-21treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 4Thomas Gleixner
Based on 1 normalized pattern(s): licensed under gplv2 or later extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 118 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com> Reviewed-by: Steve Winslow <swinslow@gmail.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190519154040.961286471@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-15ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitionsAlexandre Belloni
Separate the definitions for the emac and the gmac in different files and include them in the final board dts that uses them. Solves: Warning (unit_address_vs_reg): Node /ahb/apb/ethernet@f0028000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /ahb/apb/ethernet@f802c000 has a unit name, but no reg property Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
