commit 9a06757dcc8509c162ac00488c8c82fc98e04227 upstream.
The compatible string is incorrect. Add atmel,sama5d3-pinctrl since
it's the appropriate compatible string. Remove the
atmel,at91rm9200-pinctrl compatible string, this fallback is
useless, there are too many changes.
Signed-off-by: Santiago Esteban <Santiago.Esteban@microchip.com>
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Cc: stable@vger.kernel.org #v3.18
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Declare new nodes for the EBI and NAND controllers embedded in various
at91/sama5 SoCs.
Some peripherals are "Programmable Secure" but left as "Secure" by default.
If tried to be connected to Non-Secure DMA controller, the possibility to
leak secure data is prevented so using these peripherals with DMA1 is not
possible with this default configuration (MATRIX_SPSELR registers setup by
bootloader).
Move them to DMA0 which is an "Always-Secure" DMA controller.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Now that there is support for the sama5d4 slow clock controller, use its
driver.
Remove pullup on dbgu DTXD signal, it is a push-pull output thus the
pullup is pointless.
Add pullup on dbgu DRXD signal, it prevents the DRXD signal to be left
floating and so consuming a useless extra amount of power in crowbarred
state if nothing is externally connected to dbgu.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
Endpoint nodes have a reg property. Add their mandatory unit-address.
This solves:
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep0 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep1 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep2 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep3 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep4 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep5 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep6 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep7 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep8 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep9 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep10 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep11 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep12 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep13 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep14 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /ahb/gadget@00400000/ep15 has a reg or ranges property, but no unit name
The triggers don't need a reg property, remove it when prenset. Also remove
the unit-address from their name.
This solves:
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /ahb/apb/adc@fc034000/trigger@3 has a unit name, but no reg property
Add node to support SAMA5D4 hardware random number generator.
Signed-off-by: Mike Williams <mike@mikebwilliams.com>
[nicolas.ferre@atmel.com: reduce the register map size]
The "interrupts" property is missing from the watchdog node. Add it with
highest priority value of 7.
Change instance id of DBGU to 45.
Signed-off-by: Mohamed Jamsheeth Hajanajubudeen <mohamedjamsheeth.hajanajubudeen@atmel.com>
Fixes: 7c661394c56c ("ARM: at91: dt: add device tree file for SAMA5D4 SoC")
Cc: stable@vger.kernel.org # 3.18+
A new compatible string has been introduced: atmel,sama5d4-i2c. It
allows to use the i2c-sda-hold-time-ns property if needed.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
After the change of frequency a SAMA5D4 can reach, we have to modify the
maximum clock specification for the master clock, up to 200MHz now.
It avoids the wrong message saying that "master clk is overclocked" for this
configuration.
Add pinmux for the 4 remaining signals used in 8-bit MMC 0
bus configuration.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Reviewed-by: Josh Wu <josh.wu@atmel.com>
Synchronise the comments in mmc0 pinmux node with HSMCI0 pinmux
description in the Atmel SAMA5D4 datasheet from 24-Aug-15 page
1119, section 37.6.1, Table 37-3 .
Reported-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Change the watchdog compatible to "atmel,sama5d4-wdt" to support
SAMA5D4 watchdog driver.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
The second macb is present on all the sama5d4 SoCs. Let's add a node
reflecting it in the device tree.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The PMC is not only used to drive the clocks but also has some registers
related to other functions. One of those is for example the USB gadget
bias.
Using a syscon allows to properly separate those functions.
The crypto modules will provide HW AES/TDES/SHA for any sama5d4 board. Enable
them by default.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Correcting the dma declaration for i2c1 dma.
Signed-off-by: Holger Busse <h.busse@kathrein-sachsen.de>
Fixes: 4cc7cdf35c5f ("ARM: at91/dt: add i2c1 declaration to sama5d4")
Cc: stable@vger.kernel.org # v4.1+
The watchdog, the reset controller, the RTC, the shutdown controller, the
timer counters and the LCD PWM need the slow clock, add it where necessary.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
They'll use "atmel,sama5d3-rstc" for reset function.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
[nicolas.ferre@atmel.com: add the old compatible string as a fallback]
The ADC pinctrl is board specific, move it to the board device trees.
The property is actually atmel,adc-use-external-triggers.
at91sam9g45, at91sam9x5 and sama5 SoCs should not use
"atmel,at91sam9rl-udc" for their USB device compatible property since
this compatible is attached to a specific hardware bug fix.
Tested-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: <stable@vger.kernel.org> #4.0+
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The xdmac channel configuration is done in one cell not two. This error
prevents from probing devices correctly.
Fixes: 83906783b766 ("ARM: at91/dt: sama5d4: add aes, sha and tdes nodes")
Cc: stable@vger.kernel.org # 4.1
The ohci driver now calls clk_set_rate on the uhpck clock (which forwards
set_rate requests to its parent: the usb clock).
Remove useless references to usb clocks from ohci definitions.
The uhpck is useless for High-Speed communications, remove the reference
to this clock in all ehci definitions.
commit 111573ccd89b ("mtd: atmel_nand: check NFC busy flag by HSMC_SR
instead of NFC cmd regs")
check NFC busy by nfc SR instead of NFC cmd regs. So we don't need to
map NFC cmd registers to include NFCBUSY bit.
That means we only need map 0x08000000 instead of 0x10000000 for NFC
cmd regs.
This patch reduce the NFC cmd regs map for sama5d3 & sama5d4.
Update the pinctrl ranges property to support pioD controller whose
mapping is not contiguous with other pio controllers. Without this
update, getting resource will fail, then pinctrl probe will fail too
because there is a missing pio controller.
Add sama5d4 spi1, spi2 dt nodes & pinctrl.
Signed-off-by: Suchang Ko <suchangko@samul.kr>
[nicolas.ferre@atmel.com: split patch, reorder & whitespace fixes]
Add sama5d4 uart0, uart1 dt nodes, pinctrl and related aliases.
Also add the pinctrl for usart0, usart1.
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Merge "wireless wl12xx and omap device tree changes for v4.1" from Tony
Lindgren:
Wireless and omap changes to make wl12xx driver to use device tree
data instead of platform data from Eliad Peller <eliad@wizery.com>:
- Add device-tree support to the wlcore (wl12xx/wl18xx) driver.
- Update the current users to use the bindings instead of pdata-quirks.
- Finally, remove the deprecated wl12xx_platform_data struct
Note that da850 board file code that still uses the platform data,
but we have da850.dtsi that can be used instead. So it was decided
that we should try to remove the wl12xx support from the da850
board file as suggested by Sekhar Nori <nsekhar@ti.com>. As it's
the last patch in the series, the last patch can be simply reverted
if needed.
As this series touches quite a bit of arch code, it was suggested
by Kalle Valo <kvalo@codeaurora.org> that the whole series should
be merged via the arm-soc tree.
* tag 'omap-for-v4.1/wl12xx-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
wlcore: remove wl12xx_platform_data
ARM: dts: add wl12xx/wl18xx bindings
wlcore: add device-tree support
dt: bindings: add TI's wilink wireless device
wl12xx: use frequency instead of enumerations for pdata clocks
wlcore: set irq_trigger in board files instead of hiding behind a quirk
+ Linux 4.0-rc4
For the SAMA5D4 SoC, some LCD lines are in conflict with useful peripherals.
Remove these lines and the lowest significant bit of a 24 bit LCD. It gives
us a RGB 777 configuration.
The color arrangement for SAMA5D4 in RGB 666 takes the most significant bits of
each color line groups.
Add HLCDC node.
Add LCDC pin definitions.
The DBGU is not a simple UART and we need to be able to distinguish it from the
other UARTs, in particular to get its address and check the chip id.
The UTMI clock must be selected by any high-speed USB IP. The logic behind it
needs this particular clock.
So, correct the clock in the device tree files affected.
Reported-by: Bo Shen <voice.shen@atmel.com>
Cc: <stable@vger.kernel.org> #3.18
lcdck takes mck (not smd) as its parent. It is also assigned id 3 and not 4.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
[nicolas.ferre@atmel.com: squashed 2 related patches]
Rename lcd_clk into lcdc_clk to be consistent with sama5d3 clock
definitions.
Add ISI dt node and pinctrl settings in sama5d4.dtsi.
[nicolas.ferre@atmel.com: sort nodes in order. remove useless comments]
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Signed-off-by: Leilei Zhao <leilei.zhao@atmel.com>
Add SSC 0 and 1 nodes.
macb0 DT node can have phy child nodes, so add the #{address,
size}_cells for macb0 node.
Add alias, node declaration and pinctrl for i2c1 (aka: twi1).
Signed-off-by: Philip Attfield <phil.attfield@seqlabs.com>
