commit 4eda9b766b042ea38d84df91581b03f6145a2ab0 upstream.
The Denali NAND x-clock should be supplied by nand_x_clk, not by
nand_clk. Fix this, otherwise the Denali driver gets incorrect
clock frequency information and incorrectly configures the NAND
timing.
Cc: stable@vger.kernel.org
Fixes: d837a80d19 ("ARM: dts: socfpga: add nand controller nodes")
Cc: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
commit d9a695f3c8098ac9684689774a151cff30d8aa25 upstream.
The compatible string for the Denali NAND controller is incorrect,
fix it by replacing it with one matching the DT bindings and the
driver.
[ Upstream commit 6d97d5aba08b26108f95dc9fb7bbe4d9436c769c ]
Fixes the warning "GIC: PPI13 is secure or misconfigured" by
changing the interrupt type from level_low to edge_raising
Signed-off-by: Philipp Puschmann <pp@emlix.com>
The ethernet block clock phandle must point to the clock node which
represents the clock which directly supply the ethernet block. This
is emac_x_clk , not emacx_clk , so fix this.
The dual Cortex-A9 MPCore inside socfpga has a standard PMU unit for
each core mapped in the DAP memory space. Add support for it!
Tested with perf on a Cyclone 5 SoC DK.
Reported-by: Alberto Dassatti <alberto.dassatti@heig-vd.ch>
Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch>
Tested-by: Alberto Dassatti <alberto.dassatti@heig-vd.ch>
This makes it easier to reference the CPU nodes afterwards.
The skeleton.dtsi file is now deprecated as noted in commit 9c0da3cc61f1
("ARM: dts: explicitly mark skeleton.dtsi as deprecated"). The SoCFPGA
device trees already contain the nodes that are defined in skeleton.dtsi
(#address-cells, #size-cells, chosen, aliases, memory).
Including skeleton.dtsi is useless and will produce the following
warning when compiled with W=1:
Node /memory has a reg or ranges property, but no unit name
Node eccmgr has a unit name, but do not have a reg property as only the
child nodes do have this property. Likewise the usbphy node do not have
a reg property. This will trigger the following warnings when compiled
with W=1:
Node /soc/eccmgr@ffd08140 has a unit name, but no reg property
Node /soc/usbphy@0 has a unit name, but no reg property
Remove the superfluous unit names.
Most clock nodes in Arria5, Cyclone5 and Arria10 have a reg property but
does not have a unit name. This will trigger several warnings like this
one (when compiled with W=1):
Node /soc/clkmgr@ffd04000/clocks/periph_pll has a reg or ranges
Add the corresponding unit name to each node.
Add "altr,sdr-ctl" to the SDRAM controller node.
Add h2f and lwh2f bridges.
Add base FPGA Region to support DT overlays for FPGA programming.
Add l3regs.
Signed-off-by: Alan Tull <atull@opensource.altera.com>
v2: removed fpga-bridges, ranges, and reset-names
Adjust regs property for the FPGA manager data register to
properly reflect that it is a single 32 bit register.
Signed-off-by: Dalon Westergreen <dwesterg@altera.com>
Enable double-linefill and increase prefetch offset, which gives
considerable read performance boost. The following numbers were
obtained using lmbench 3.0 bw_mem tool, for easier comparison, the
numbers are pasted in two columns. The test machine has Cyclone V
SoC running at 800MHz MPU clock and 512MiB 333MHz 16bit DDR3 DRAM.
Without patch | With patch
$ for i in rd wr rdwr cp fwr frd fcp bzero bcopy ; do echo $i ; bw_mem 64M $i ; done
rd | rd
64.00 526.46 | 64.00 1151.06
wr | wr
64.00 329.95 | 64.00 346.14
rdwr | rdwr
64.00 342.07 | 64.00 367.24
cp | cp
64.00 239.79 | 64.00 322.47
fwr | fwr
64.00 1027.90 | 64.00 1025.38
frd | frd
64.00 322.36 | 64.00 641.89
fcp | fcp
64.00 256.99 | 64.00 408.41
bzero | bzero
64.00 1028.43 | 64.00 1025.07
bcopy | bcopy
64.00 294.73 | 64.00 357.19
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add the denali nand controller to the socfpga dtsi.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Add the qspi node to the socfpga dtsi file.
Enable the bit(22) shared-override bit for the SoCFPGA family. While at it,
enable the prefetch-data and prefetch-instr settings for the Arria10.
Add the resets property for the 2 USB controllers.
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
plus a couple of related 64-bit updates:
New SoC support:
- Allwinner A83T
- Axis Artpec-6 SoC
- Mediatek MT7623 SoC
- TI Keystone K2G SoC
- ST Microelectronics stm32f469
New board or machine support:
- ARM Juno R2
- Buffalo Linkstation LS-QVL and LS-GL
- Cubietruck plus
- D-Link DIR-885L
- DT support for ARM RealView PB1176 and PB11MPCore
- Google Nexus 7
- Homlet v2
- Itead Ibox
- Lamobo R1
- LG Optimus Black
- Logicpd dm3730
- Raspberry Pi Model A
Other changes include
- Lots of updates for Qualcomm APQ8064, MSM8974 and others
- Improved support for Nokia N900 and other OMAP machines
- Common clk support for lpc32xx
- HDLCD display on ARM
- Improved stm32f429 support
- Improved Renesas device support, r8a779x and others
- Lots of Rockchip updates
- Samsung cleanups
- ADC support for Atmel SAMA5D2
- BCM2835 (Raspberry Pi) improvements
- Broadcom Northstar Plus enhancements
- OMAP GPMC rework
- Several improvements for Atmel SAMA5D2 / Xplained
- Global change to remove inofficial "arm,amba-bus" compatible
string"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits)
ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus"
ARM: dts: artpec: dual-license on artpec6.dtsi
ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT
arm64: dts: juno/vexpress: fix node name unit-address presence warnings
arm64: dts: foundation-v8: add SBSA Generic Watchdog device node
ARM: dts: at91: sama5d2 Xplained: add leds node
ARM: dts: at91: sama5d2 Xplained: add user push button
ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host
ARM: dts: stm32f429: Enable Ethernet on Eval board
ARM: dts: omap3-sniper: TWL4030 keypad support
Revert "ARM: dts: DRA7: Add dt nodes for PWMSS"
ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND
ARM: dts: dm814x: dra62x: Fix NAND device nodes
ARM: dts: stm32f429: Add Ethernet support
ARM: dts: stm32f429: Add system config bank node
ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes
ARM: dts: at91: sama5d2: add dma properties to UART nodes
ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node
ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load
ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
Add the device tree entries and bindings needed to support the Altera L2
cache and On-Chip RAM EDAC. This patch relies upon an earlier patch to
declare and setup On-chip RAM properly:
8b907c8b62ac ("arm: dts: socfpga: Add OCRAM node")
Signed-off-by: Thor Thayer <tthayer@opensource.altera.com>
Acked-by: Rob Herring <robh@kernel.org>
Cc: devicetree@vger.kernel.org
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: galak@codeaurora.org
Cc: grant.likely@linaro.org
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: ijc+devicetree@hellion.org.uk
Cc: Kumar Gala <galak@codeaurora.org>
Cc: linux@arm.linux.org.uk
Cc: linux-doc@vger.kernel.org
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: m.chehab@samsung.com
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Rob Herring <robh+dt@kernel.org>
Link: http://lkml.kernel.org/r/1455132384-17108-2-git-send-email-tthayer@opensource.altera.com
The socfpga.dtsi explicitly enabled MMC support, but not all boards are
equiped with an MMC card. There are setups which only have QSPI NOR.
Therefore, disable the MMC support on socfpga.dtsi level and enable it
on per-board basis.
Cc: Alan Tull <atull@altera.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Thor Thayer <tthayer@altera.com>
Cc: Vince Bridgers <vbridgers2013@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux into next/dt
SoCFPGA dts cleanup for v4.4
- Re-order DTS nodes into correct alphabetical order
* tag 'socfpga_for_v4.4_cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux:
ARM: socfpga: dts: sort nodes alphabetically
The sorting policy for this file is alphabetically.
Reorder all nodes, that are out of place.
Add FPGA manager to device tree for SoCFPGA.
Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com>
SoCFPGA DTS updates for v4.3, take 2
- Add DTS property "altr,modrst-offset" for reset driver to
use
- Add updated reset defines for the reset driver
- Add reset property for EMACs on Arria10
* tag 'socfpga_dts_for_v4.3_part_2' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux:
ARM: socfpga: dts: Add resets for EMACs on Arria10
ARM: socfpga: dts: add "altr,modrst-offset" property
dt-bindings: Add reset manager offsets for Arria10
The "altr,modrst-offset" property represents the offset into the reset manager
that is the first register to be used by the driver to bring peripherals out
of reset.
The dbg_base_clk can also have osc1 has a parent.
The gates for the clocks coming out of the sdram pll
were missing. The change adds the missing nodes to
the device tree.
Signed-off-by: Matthew Gerlach <mgerlach@opensource.altera.com>
The correct clock for the HPS gpio(s) should be the l4_mp_clk.
The l3_sp_clk's parent should be the l3_mp_clk. This will account for
the extra divider that is present for the l3_mp_clk.
The dbg_clk's parent should be the dbg_at_clk. This will account for
the extra divider that is present for the dbg_at_clk.
Just in case the firmware did not enable data and instruction prefetch in
the L2 cache controller, we enable it in the kernel.
SoCFPGA updates for v4.2 part 3
- Add SCU node for Arria 10
- Add enable-method for cpu nodes
- Add SDRAM controller binding doc
- Enable gpio-leds on SoCFPGA Socrates board
* tag 'socfpga_dts_for_v4.2_part_3' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux:
ARM: socfpga: socrates: add gpio-leds
ARM: socfpga: socrates: enable gpio0/1
ARM: socfpga: dts: add sdram controller dt binding doc
ARM: socfpga: dts: add enable-method property for cpu nodes
ARM: socfpga: dts: add the a9-scu node for arria10
Add the enable-method property for the cpu node on socfpga.dtsi and
socfpga_arria10.dtsi. This is for CPU_METHOD_OF_DECLARE to use to enable
the secondary core.
Merge "SoCFPGA update for v4.2 part 2" from Dinh Nguyen:
- Add a DTS node for the A9 SCU
* tag 'socfpga_dts_for_v4.2_part_2' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux:
Add the dts node for the A9 SCU.
Add tx-fifo-depth and rx-fifo-depth devicetree properties for socfpga
stmmac. These devicetree properties will be used to configure certain
features of the stmmac on the socfpga.
Signed-off-by: Vince Bridgers <vbridger@opensource.altera.com>
The CIU(Card Interface Unit) get its clock from the sdmmc_clk_divided clock
which is used to clock the card. The sdmmc_clk_divided clock is the sdmmc_clk
passed through a fixed divider of 4. This patch adds the sdmmc_clk_divided
node and makes the sdmmc_clk it's parent.
v2: renamed ciu_clk to sdmmc_clk_divided
The socfpga.dtsi currently has the wrong interrupt number set for SPI master 1
Trying to use the master without this change results in the kernel boot
process waiting forever for an interrupt that will never occur while
attempting to probe any slave devices configured in the device tree as being
under SPI master 1.
The change works for the Cyclone V, and according to the Arria 5 handbook
should be good there too.
Signed-off-by: Mark James <maj@jamers.net>
Acked-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
socfpga.dtsi is missing the DMA channels for the uart nodes.
This will produce the following errors:
of_dma_request_slave_channel: dma-names property of node '/soc/serial0@ffc02000' missing or empty
ttyS0 - failed to request DMA
Provide the correct DMA channels to fix this.
git://git.rocketboards.org/linux-socfpga-next into next/dt
Pull "SoCFPGA DTS updates for v3.19" from Dinh Nguyen:
- Add DTS support for a new chip in the SOCFPGA family, the Arria 10.
- Enable watchdog node.
- Add SPI nodes.
- Add the OCRAM node.
* tag 'socfpga_dts_updates_for_v3.19' of git://git.rocketboards.org/linux-socfpga-next:
arm: dts: socfpga: Add a base DTSI for Altera's Arria10 SOC
arm: dts: socfpga: enable watchdog for socfpga platform
arm: dts: socfpga: Add SPI nodes to SOCFPGA DT.
Add 2 SPI nodes to SOCFPGA device tree.
Add a 64KB ocram node for SOCFPGA.
Since the Synopsys GPIO IP can support multiple ports of varying widths, it
would make more sense to have the GPIO node DTS entry as this:
gpio0: gpio@ff708000{
porta{
Also, this is documented in the snps-dwapb-gpio.txt.
Suggested-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Add the Altera SDRAM EDAC bindings and device tree changes to the Altera SoC
project.
There was a discussion thread on whether this driver should be an mfd driver
or just make use of syscon, which is already a mfd. Ultimately, the
decision to use a simple syscon interface was reached.[1]
[1] https://lkml.org/lkml/2014/7/30/514
Acked-by: Pavel Machek <pavel@denx.de>
[dinguyen] cleaned-up commit header and remove version history.
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
This patch adds socfpga Ethernet filter attributes for multicast
and unicast filters per Synopsys Ethernet IP configuration chosen
by Altera for the Cyclone 5 and Arria SOC FPGAs.
Signed-off-by: Vince Bridgers <vbridgers2013@gmail.com>
add #reset-cells to socfpga.dtsi. This was missing from the
latest updates and caused the socfpga reset controller to fail
to load like so:
ffd05000.rstmgr: /soc/rstmgr@ffd05000 missing #reset-cells property
probe of ffd05000.rstmgr failed with error -22
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
The SoCFPGA has two watchdog timers. Add them to the dtsi.
[dinh: modified patch to have correct irq flag]
The cycloneV has three gpio controllers, each one with 29 gpios. This patch
adds the three controller with the gpio driver which is now sitting the
gpio tree.
Acked-by: Alan Tull <atull@altera.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
The mpu_clk, main_clk, and dbg_base_clk outputs from the main PLL go through a
pre-divider. Update socfpga.dtsi to represent those dividers for these
clocks.
Re-use the "div-reg" property that was used for the socfpga-gate-clock as this
is the same thing. Also update the documentation.
