commit ce3bf934f919a7d675c5b7fa4cc233ded9c6256e upstream.
The address in the SDRAM node was incorrect. Fix this to agree with the
correct address and to match the reg definition block.
Cc: stable@vger.kernel.org
Fixes: 54b4a8f57848b("arm: socfpga: dts: Add Arria10 SDRAM EDAC DTS support")
Signed-off-by: Thor Thayer <thor.thayer@linux.intel.com>
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
commit 3877ef7a1ccecaae378c497e1dcddbc2dccb664c upstream.
The NAND compatible "denali,denal-nand-dt" property has never been used and
is obsolete. Remove it.
Fixes: f549af06e9b6("ARM: dts: socfpga: Add NAND device tree for Arria10")
commit 975ba94c2c3aca4d9f1ae26f3916d7787495ce86 upstream.
Remove the unused bus-num node and change num-chipselect
to num-cs to match SPI bindings.
Fixes: f2d6f8f817814 ("ARM: dts: socfpga: Add SPI Master1 for Arria10 SR chip")
The skeleton.dtsi file is now deprecated as noted in commit 9c0da3cc61f1
("ARM: dts: explicitly mark skeleton.dtsi as deprecated"). The SoCFPGA
device trees already contain the nodes that are defined in skeleton.dtsi
(#address-cells, #size-cells, chosen, aliases, memory).
Including skeleton.dtsi is useless and will produce the following
warning when compiled with W=1:
Node /memory has a reg or ranges property, but no unit name
Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch>
Node eccmgr has a unit name, but do not have a reg property as only the
child nodes do have this property. Likewise the usbphy node do not have
a reg property. This will trigger the following warnings when compiled
with W=1:
Node /soc/eccmgr@ffd08140 has a unit name, but no reg property
Node /soc/usbphy@0 has a unit name, but no reg property
Remove the superfluous unit names.
Most clock nodes in Arria5, Cyclone5 and Arria10 have a reg property but
does not have a unit name. This will trigger several warnings like this
one (when compiled with W=1):
Node /soc/clkmgr@ffd04000/clocks/periph_pll has a reg or ranges
Add the corresponding unit name to each node.
Add the device tree entries needed to support the EMAC AXI
bus settings on the Arria10 SoCFPGA chip.
Add "altr,sdr-ctl" to the SDRAM controller node.
Add the base FPGA region for DT overlay support in FPGA programming.
Signed-off-by: Alan Tull <atull@opensource.altera.com>
Signed-off-by: Matthew Gerlach <mgerlach@opensource.altera.com>
Add socfpga_arria10_socdk_nand.dts board file for supporting NAND.
Signed-off-by: Graham Moore <grmoore@opensource.altera.com>
v2: move nand dts node to socfpga_arria10.dtsi
Add the FPGA manger DTS entry for Arria10.
Add the QSPI device node for Arria10 SOC.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add the Altera Arria10 SPI Master Node in preparation for
the A10SR MFD node.
Signed-off-by: Thor Thayer <tthayer@opensource.altera.com>
Enable the bit(22) shared-override bit for the SoCFPGA family. While at it,
enable the prefetch-data and prefetch-instr settings for the Arria10.
Add the device tree entries needed to support the Altera USB
FIFO buffer EDAC on the Arria10 chip.
Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: devicetree@vger.kernel.org
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/1468512408-5156-11-git-send-email-tthayer@opensource.altera.com
Add the device tree entries needed to support the Altera DMA
Link: http://lkml.kernel.org/r/1468512408-5156-10-git-send-email-tthayer@opensource.altera.com
Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
Add the device tree entries needed to support the Altera Ethernet FIFO
Link: http://lkml.kernel.org/r/1466603939-7526-9-git-send-email-tthayer@opensource.altera.com
The notion of which uart instance is serial0 or serial1
is board specific rather than generic to the chip. This
patch removes the serial aliases from generic chip dtsi
and adds an appropriate alias to the board specific dtsi.
By making the alias for serial0 point to uart1 for the arria10_socdk,
the linux boot command line supports specifying console=ttyS0,115200
for backwards compatibility, and it supports not specifying
the console at all.
Changes to support ECC Manager as SDRAM IRQ parent by
1) updating IRQ property values to correct child IRQs
2) moving node under ECC Manager.
Changes to support IRQ controller implementation including adding
new property irq-controller to eccmgr and adding IRQ property
to children.
Add the resets property for the 2 USB controllers.
Add the device tree entries needed to support the Altera On-Chip
RAM EDAC on the Arria10 chip.
Add the device tree entries needed to support the Altera L2
cache EDAC on the Arria10 chip.
The PL330 DMA driver will not load on Arria10 without devicetree entries
for clocks and clock_names. This patch adds those entries. It also adds
the ninth interrupt, which is required for error detection.
The CIU clock for the SD/MMC should be the sdmmc_clk and not the
sdmmc_free_clk. Also, add the correct phase shift the sdmmc_clk.
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
Add the required clock fields for all the I2C nodes. Also add missing clock
fields for UART0 and USB1.
git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux into next/dt
SoCFPGA DTS updates for v4.3, take 2
- Add DTS property "altr,modrst-offset" for reset driver to
use
- Add updated reset defines for the reset driver
- Add reset property for EMACs on Arria10
* tag 'socfpga_dts_for_v4.3_part_2' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux:
ARM: socfpga: dts: Add resets for EMACs on Arria10
ARM: socfpga: dts: add "altr,modrst-offset" property
dt-bindings: Add reset manager offsets for Arria10
Add the reset property for the EMAC controllers on Arria10.
The "altr,modrst-offset" property represents the offset into the reset manager
that is the first register to be used by the driver to bring peripherals out
of reset.
Use stdout-path dts property for kernel console.
Pull ARM SoC DT updates from Kevin Hilman:
"As usual, quite a few device-tree updates in ARM land. There was one
minor churn in DTs due to relicensing under a dual-license, and lots
of little additions of new peripherals, features etc, but nothing
really exciting to call to your attention. Some higlights, focsuing
on support for new SoCs and boards:
- AT91: new boards: Overkiz, Acme Systems' Arietta G25
- tegra: HDA support
- bcm: new platforms: Buffalo WXR-1900DHP, SmartRG SR400ac, ASUS
RT-AC87U
- mvebu: new platforms: Compulab CM-A510, Armada 385-based Linksys
boards, DLink DNS-327L
- OMAP: new platforms: Baltos IR5221, LogicPD Torpedo, Toby-Churchill
SL50
- ARM: added support for Juno r1 board
- sunxi: A33 SoC support; new boards: A23 EVB, SinA33, GA10H-A33,
Mele A1000G
- imx: i.MX7D SoC support; new boards: Armadeus Systems APF6,
Gateworks GW5510, and aristainetos2 boards
- hisilicon: hi6220 SoC support; new boards: 96boards hikey"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (462 commits)
ARM: hisi: revert changes from hisi/hip04-dt branch
ARM: nomadik: set proper compatible for accelerometer
ARM64: juno: add GPIO keys
ARM: at91/dt: sama5d4: fix dma conf for aes, sha and tdes nodes
ARM: dts: Introduce STM32F429 MCU
ARM: socfpga: dts: enable ethernet for Arria10 devkit
ARM: dts: k2l: fix the netcp range size
ARM: dts: k2e: fix the netcp range size
ARM: dts: k2hk: fix the netcp range size
ARM: dts: k2l-evm: Add device bindings for netcp driver
ARM: dts: k2e-evm: Add device bindings for netcp driver
ARM: dts: k2hk-evm: Add device bindings for netcp driver
ARM: BCM5301X: Add DT for Asus RT-AC87U
ARM: BCM5301X: add IRQ numbers for PCIe controller
ARM: BCM5301X: add NAND flash chip description
arm64: dts: Add dts files for Hisilicon Hi6220 SoC
clk: hi6220: Document devicetree bindings for hi6220 clock
arm64: hi6220: Document devicetree bindings for Hisilicon hi6220 SoC
ARM: at91/dt: sama5d4ek: mci0 uses slot 0
ARM: at91/dt: kizbox: fix mismatch LED PWM device
Add support for the Arria10 SDRAM EDAC. Update the bindings document for
the new match string.
Cc: dinguyen@opensource.altera.com
Cc: galak@codeaurora.org
Cc: grant.likely@linaro.org
Cc: ijc+devicetree@hellion.org.uk
Cc: m.chehab@samsung.com
Cc: mark.rutland@arm.com
Cc: pawel.moll@arm.com
Cc: robh+dt@kernel.org
Cc: tthayer.linux@gmail.com
Link: http://lkml.kernel.org/r/1433428128-7292-5-git-send-email-tthayer@opensource.altera.com
Update the arria10 gmac nodes with all the necessary properties for ethernet
to function on the Arria10 devkit.
Signed-off-by: Kevin Hilman <khilman@linaro.org>
SoCFPGA updates for v4.2 part 3
- Add SCU node for Arria 10
- Add enable-method for cpu nodes
- Add SDRAM controller binding doc
- Enable gpio-leds on SoCFPGA Socrates board
* tag 'socfpga_dts_for_v4.2_part_3' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux:
ARM: socfpga: socrates: add gpio-leds
ARM: socfpga: socrates: enable gpio0/1
ARM: socfpga: dts: add sdram controller dt binding doc
ARM: socfpga: dts: add enable-method property for cpu nodes
ARM: socfpga: dts: add the a9-scu node for arria10
Add the enable-method property for the cpu node on socfpga.dtsi and
socfpga_arria10.dtsi. This is for CPU_METHOD_OF_DECLARE to use to enable
the secondary core.
Add a dts node for the A9 SCU on the Arria10 platform.
Add all the clock nodes for the Arria10 platform. At the same time, update
the peripherals with their respective clocks property.
v2: Add the l4_sys_free_clk node
Add tx-fifo-depth and rx-fifo-depth devicetree properties for socfpga
stmmac. These devicetree properties will be used to configure certain
features of the stmmac on the socfpga.
Signed-off-by: Vince Bridgers <vbridger@opensource.altera.com>
Add multicast-filter-bins and perfect-filter-entries configuration properties
to the socfpga devicetree for the Arria 10 socfpga.
Arria10 devkit is using UART1 for the debug uart port. Remove
unused aliases.
v2: Add removal of unused aliases
Add status = "disabled" in the base DTSI for Arria10. The SDMMC and uart
nodes should be enabled in the appropriate board file.
The Arria 10 is latest SOC+FPGA from the Altera SOCFPGA platform. The Arria10
SOC shares some similarities with the SOCFPGA Cyclone5 and Arria5, but there
are enough differences to warrant a new base dtsi.
The differences are:
* 3 EMAC controllers
* 5 I2C controllers
* 3 SPI controllers
* 1.5 GHZ dual A9s
* Support for DDR4
Besides the usual memory map and IRQ changes, the clock framework will be
different, so this patch just adds the fixed-clocks.
