Add the device tree entries needed to support the Altera SD/MMC
FIFO buffer EDAC on the Arria10 chip.
Signed-off-by: Thor Thayer <tthayer@opensource.altera.com>
Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: devicetree@vger.kernel.org
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/1470753653-23465-4-git-send-email-tthayer@opensource.altera.com
Enable SD highspeed support for the SoCFPGA Arria10 devkit.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Rename the socfpga_arria10_socdk board file to socfpga_arria10_socdk_sdmmc
as Arria 10 devkit cannot support SDMMC and QSPI at the same time. Thus
we will need to have 2 separate board files, one for SDMMC and one for
QSPI. We also add a new base board dtsi file, socfpga_arria10_socdk.dtsi
so that we use common peripherals for each flavor of the devkits.
Add the sdmmc node to the socfpga_arria10_socdk_sdmmc.dts board file.
