path: root/arch/arm/boot/dts/socfpga_arria5_socdk.dts
2017-03-06ARM: dts: socfpga: Add unit name to memory nodesFlorian Vaussard
Memory nodes in Arria5, Cyclone5 and Arria10 do not have a unit name. This will trigger several warnings like this one (when compiled with W=1): Node /memory has a reg or ranges property, but no unit name Add the corresponding unit name to each node. Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2017-01-04ARM: dts: socfpga: set desired i2c clock on Cyclone5 and Arria5 devkitsDinh Nguyen
The I2C LCD display on the Cyclone5 and Arria5 devkits is only capable of the standard 100 kHz clock. Set the "clock-frequency" of the I2C node to be 100000. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2017-01-04ARM: dts: socfpga: enable GPIO and LEDs for Cyclone5 and Arria5 devkitsDinh Nguyen
Enable all the GPIO ports and define the GPIO-based leds on the Cyclone5 and Arria5 devkits. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2016-11-08ARM: dts: socfpga: Enable QSPI on the Arria5 devkitDinh Nguyen
Enable the QSPI node and add the flash chip. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-21ARM: socfpga: dts: Enable MMC support at correct place in the DTMarek Vasut
The socfpga.dtsi explicitly enabled MMC support, but not all boards are equiped with an MMC card. There are setups which only have QSPI NOR. Therefore, disable the MMC support on socfpga.dtsi level and enable it on per-board basis. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Alan Tull <atull@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Olof Johansson <olof@lixom.net> Cc: Thor Thayer <tthayer@altera.com> Cc: Vince Bridgers <vbridgers2013@gmail.com> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-07-20ARM: dts: socfpga: use stdout-path for chosen nodeDinh Nguyen
Use stdout-path dts property for kernel console. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2014-10-22ARM: dts: socfpga: Add a 3.3V fixed regulator nodeDinh Nguyen
Without the 3.3V regulator node, the SDMMC driver will give these warnings: dw_mmc ff704000.dwmmc0: No vmmc regulator found dw_mmc ff704000.dwmmc0: No vqmmc regulator found This patch adds the regulator node, and points the SD/MMC to the regulator. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> Reviewed-by: Doug Anderson <dianders@chromium.org> --- v3: Rename nodes to have schematic-name_regulator and remove "boot-on" and "always-on" v2: Move the regulator nodes to their respective board dts file and correctly rename them to match the schematic
2014-09-04ARM: dts: socfpga: remove extra alias in the ArriaV devkitDinh Nguyen
commit [2755e187 dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.] added an extra ethernet alias in the ArriaV devkit board file. This patch removes it. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2014-05-05ARM: socfpga: dts: Add DTS entries for USBDinh Nguyen
Update all the SOCFPGA DTS files with USB entries. Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
2014-05-05ARM: socfpga: dts: add eeprom and rtc on i2c0Dinh Nguyen
The Altera Cyclone5 and Arria5 devkit has an EEPROM and a RTC on the board. This patch adds support for them. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> --- v2: Remove LCD as the driver has not been upstreamed.
2014-05-05ARM: socfpga: dts: convert to preprocessor includesSteffen Trumtrar
Convert all socfpga DT files to the dtc preprocessor include syntax. This allows to include header files in the devicetrees like other SoC-types already do. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
2014-03-29dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.Dinh Nguyen
This patch adds the dts bindings documenation for the Altera SOCFPGA glue layer for the Synopsys STMMAC ethernet driver. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-10-09dts: socfpga: Add support for Altera's SOCFPGA Arria V boardDinh Nguyen
Add support for a new SOCFPGA board that has an Arria V FPGA along with dual ARM Cortex-A9 cores. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: devicetree@vger.kernel.org CC: linux-arm-kernel@lists.infradead.org
