path: root/arch/arm/boot/dts/socfpga_cyclone5_de0_sockit.dts
2015-12-21ARM: socfpga: dts: Enable MMC support at correct place in the DTMarek Vasut
The socfpga.dtsi explicitly enabled MMC support, but not all boards are equiped with an MMC card. There are setups which only have QSPI NOR. Therefore, disable the MMC support on socfpga.dtsi level and enable it on per-board basis. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Alan Tull <atull@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Olof Johansson <olof@lixom.net> Cc: Thor Thayer <tthayer@altera.com> Cc: Vince Bridgers <vbridgers2013@gmail.com> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-07-21ARM: dts: socfpga: Add support of Terasic DE0 Atlas boardDalon Westergreen
The Terasic DE0 Atlas board is also known as the DE0-Nano board. This patch adds the DTS board file for the DE0-Nano Sockit board, and not the DE0 Nano "Development Board". Signed-off-by: Dalon Westergreen <dwesterg@gmail.com> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> --- v3: Updated skew settings for the gmac1 node as this board is using the KSZ9031 PHY instead of the 9021 PHY. v2: use stdpath-out for console and remove comment regarding u-boot ethaddr
