Memory nodes in Arria5, Cyclone5 and Arria10 do not have a unit name.
This will trigger several warnings like this one (when compiled with
W=1):
Node /memory has a reg or ranges property, but no unit name
Add the corresponding unit name to each node.
Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch>
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
Enable the QSPI node and add the flash chip.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
v3: Use n25q00 for the compatible entry for the flash part and
tested on SoCKit
v2: Remove partition entries for the SoCKIT
Add a more specific board compatible entry for all of the SOCFPGA
Cyclone 5 based boards.
v3: Be a bit more specific with the c5 dk and sockit, use
"altr,socfpga-cyclone5-socdk" and "terasic,socfpga-cyclone5-sockit"
v2: remove extra space and add a comma between compatible entries
Add support for the keys and flip-switches on the SoCFPGA SoCkit board.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Add support for the blue LEDs on the SoCFPGA SoCkit board.
The socfpga.dtsi explicitly enabled MMC support, but not all boards are
equiped with an MMC card. There are setups which only have QSPI NOR.
Therefore, disable the MMC support on socfpga.dtsi level and enable it
on per-board basis.
Cc: Alan Tull <atull@altera.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Thor Thayer <tthayer@altera.com>
Cc: Vince Bridgers <vbridgers2013@gmail.com>
Pull ARM DT updates from Olof Johansson:
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
Use stdout-path dts property for kernel console.
This patch reorders the nodes alphabetically
Signed-off-by: Walter Lozano <walter@vanguardiasur.com.ar>
This patch fixes the formating of DTS bindings for the adxl34x digital
accelerometer, and updates the compatible string after the deprecation
of "adxl345x" compatible string.
Acked-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
This patch adds the DTS bindings for the adxl34x digital
accelerometer.
Without the 3.3V regulator node, the SDMMC driver will give these warnings:
dw_mmc ff704000.dwmmc0: No vmmc regulator found
dw_mmc ff704000.dwmmc0: No vqmmc regulator found
This patch adds the regulator node, and points the SD/MMC to the regulator.
Reviewed-by: Doug Anderson <dianders@chromium.org>
v3: Rename nodes to have schematic-name_regulator and remove "boot-on" and
"always-on"
v2: Move the regulator nodes to their respective board dts file and
correctly rename them to match the schematic
Update all the SOCFPGA DTS files with USB entries.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Convert all socfpga DT files to the dtc preprocessor include syntax.
This allows to include header files in the devicetrees like other
SoC-types already do.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
This patch adds the dts bindings documenation for the Altera SOCFPGA glue
layer for the Synopsys STMMAC ethernet driver.
This adds basic support for the terasic SoCkit board.
The board includes an Altera Cyclone 5 SoC.
[Dinh Nguyen] - Changed to 115200 for baudrate in dts bootargs
