path: root/arch/arm/boot/dts/socfpga_cyclone5_socrates.dts
2018-11-28arm: dts: socfpga*.dts*: use SPDX-License-IdentifierSimon Goldschmidt
Follow the recent trend for the license description. This is also in an effort to fully sync the devicetrees with U-Boot. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-10-09ARM: dts: socfgpa: remove ethernet aliases from dtsiDinh Nguyen
Not all boards use two ethernet devices and/or use them in different order. As almost all in-tree boards already define their own ethernet aliases, remove them from the dtsi and add the aliases to the two boards, that are missing their own definition. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> [dinguyen@kernel.org: rebased to latest dts changes] Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-08-30ARM: dts: socfpga: use stdout-path for chosen nodeSimon Goldschmidt
Use stdout-path dts property for kernel console. There were two socfpga boards left not using stdout-path: socrates and vining. Make sure they match the other boards. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2017-03-06ARM: dts: socfpga: Remove unit name for LEDs in EBV SOCratesFlorian Vaussard
GPIO LEDs in the Cyclone5 EBV SOCrates board have a unit name but no reg property. Indeed, GPIO LEDs do not need such a property. They do not need a unit name neither. This will trigger the following warnings when compiled with W=1: Node /gpio-leds/led@0 has a unit name, but no reg property Node /gpio-leds/led@1 has a unit name, but no reg property Node /gpio-leds/led@2 has a unit name, but no reg property The solution is to remove the unit name. In order to have unique node names, a rename is necessary. This should be harmless as all the LEDs have a 'label' property, hence their name do not derive from the node name and will stay the same after this patch. Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2017-03-06ARM: dts: socfpga: Add unit name to memory nodesFlorian Vaussard
Memory nodes in Arria5, Cyclone5 and Arria10 do not have a unit name. This will trigger several warnings like this one (when compiled with W=1): Node /memory has a reg or ranges property, but no unit name Add the corresponding unit name to each node. Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2016-10-18ARM: dts: socfpga: socrates: enable qspiSteffen Trumtrar
Enable the qspi controller on the socrates and add the flash chip. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2016-07-22ARM: dts: fix STMicroelectronics compatible stringsStefan Agner
Replace the non-standard vendor prefix stm with st for STMicroelectronics. The drivers do not specify the vendor prefixes since the I2C Core strips them away from the DT provided compatible string. Therefore, changing existing device trees does not have any impact on device detection. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Rob Herring <robh@kernel.org>
2016-04-11ARM: dts: socfpga: Drop gmac0 from CV dtsiMarek Vasut
The socfpga_cyclone5.dtsi is included by all DTS files which describe boards using the Cyclone V SoC. The Cyclone V SoC has two ethernet controllers and different boards use none, one or both of them. The /soc/ethernet@ff702000/{} node in socfpga_cyclone5.dtsi unconditionaly enabled gmac0 interface, which is clearly wrong for those boards which use gmac1 interface instead. This patch removes the entire /soc/ethernet@ff702000/{} node from the socfpga_cyclone5.dtsi file. This is correct, since all of the board which include this file also have correct gmac0 or gmac1 node present in them. Minor correction had to be done to EBV SoCrates, which didn't define PHY mode explicitly, but inherited it from the socfpga_cyclone5.dtsi . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-06-02ARM: socfpga: socrates: add gpio-ledsSteffen Trumtrar
The SOCrates has three HPS LEDs that can be turned on/off via gpio. Use the first one has heartbeat and add the other two as free LEDs. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-06-02ARM: socfpga: socrates: enable gpio0/1Steffen Trumtrar
Enable the gpio0+1 controller. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2014-05-05ARM: socfpga: dts: convert to preprocessor includesSteffen Trumtrar
Convert all socfpga DT files to the dtc preprocessor include syntax. This allows to include header files in the devicetrees like other SoC-types already do. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
2014-05-05ARM: socfpga: dts: add rtc on i2c0 to socratesSteffen Trumtrar
The SOCrates has an M41T82M RTC on i2c0. Add it. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
2014-05-05ARM: socfpga: dts: add support for EBV SOCratesSteffen Trumtrar
The SOCrates is a SOCFpga-Cyclone5 based board from EBV. Add support for it. Reviewed-by: Pavel Machek <pavel@denx.de> Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
