In two of the gen5 socfpga devicetree files, there are some lines
indented using spaces instead of tabs.
Fix this by correctly indenting them with tabs.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
Follow the recent trend for the license description.
This is also in an effort to fully sync the devicetrees with U-Boot.
Enable the qspi controller on sodia board and add the flash chip
(n25q512a).
Memory nodes in Arria5, Cyclone5 and Arria10 do not have a unit name.
This will trigger several warnings like this one (when compiled with
W=1):
Node /memory has a reg or ranges property, but no unit name
Add the corresponding unit name to each node.
Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch>
Add a more specific board compatible entry for all of the SOCFPGA
Cyclone 5 based boards.
v3: Be a bit more specific with the c5 dk and sockit, use
"altr,socfpga-cyclone5-socdk" and "terasic,socfpga-cyclone5-sockit"
v2: remove extra space and add a comma between compatible entries
Add support for board based on the Altera Cyclone V SoC.
This board has the following functions:
- 1 GiB of DRAM
- 1 Gigabit ethernet
- 1 SD card slot
- 1 USB gadget port
- QSPI NOR Flash
- I2C EEPROMs and I2C RTC
- DVI output
- Audio port
This commit supports without QSPI, DVI and Audio.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
