commit f8975cb1b8a36d0839b6365235778dd9df1d04ca upstream.
This fixes the following warning by also sending the flags argument for
gpio controllers:
Property 'cs-gpios', cell 6 is not a phandle reference in
/ahb/apb/spi@e0100000
Fixes: 8113ba917dfa ("ARM: SPEAr: DT: Update device nodes")
Cc: stable@vger.kernel.org # v3.8+
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Keyboard driver for GPIO buttons(gpio-keys) checks for the legacy
"gpio-key,wakeup" boolean property to enable gpio buttons as wakeup
source.
Few dts files assign value "1" to gpio-key,wakeup which is incorrect.
Since the presence of the boolean property indicates it is enabled,
value of "0" or "1" have no significance.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property which inturn fixes the above mentioned issue.
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Switch to my kernel.org alias instead of a badly named gmail address,
which I rarely use.
This patch adds necessary DT nodes for pcie controllers and miphys for SPEAr13xx
SoCs.
SPEAr1310 has 3 PCIe ports and SPEAr1340 has 1, which are multiplexed with
ahci/sata pins. By default evaluation board of both controller works in ahci
mode. Because of this, these nodes are marked "disabled" by default.
In order to use pcie controller on evaluation boards do necessary modifications
on board and enable (By replacing "disabled" with "okay") pcie and miphy from
respective 'evb' dtsi file.
Phy specific initialization was previously done from spear1340.c, which isn't
required anymore as we have separate drivers for it. Remove it.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Pratyush Anand <pratyush.anand@st.com>
Signed-off-by: Mohit Kumar <mohit.kumar@st.com>
[viresh: fixed logs/cclist/checkpatch warnings, clubbed multiple patches into one]
This patch adds multiple device nodes for SPEAr machines and boards.
Signed-off-by: Bhavna Yadav <bhavna.yadav@st.com>
Signed-off-by: Deepak Sikri <deepak.sikri@st.com>
Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com>
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
Signed-off-by: Vijay Kumar Mishra <vijay.kumar@st.com>
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com>
amba-pl011 driver supports two pin state "default" and "sleep" and it
expect from dt to provide this pinctrl states and phandler otherwise it
gives a warning message.
To remove this warning message pass default state with null phandler to uart
pins in device node (In our case all the pins are configured in default states
so we pass null phandler to pins).
This patch modifies the DT bindings for the GMAC IP existings for the
SPEAr family. The DT bindings now additionally pass the phy mode as a
configuration parameter for the ethernet device.
This patch fixes existing DT support for all SPEAr SoC's. This includes:
- Removing few nodes from board files
- Updating DT data of few nodes
- Updating ranges of few busses
- Moving devices to correct parent bus
This patch enhances partition information of MTD devices like fsmc-nand and
spear-smi.
This patch updates pinctrl configuration for SPEAr SoC's.
This patch adds plgpio nodes in SPEAr DT files.
viresh.kumar@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with viresh.linux@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'
Signed-off-by: Viresh Kumar <viresh.linux@gmail.com>
This patch adds machines/boards dts{i} files for SPEAr1310 and SPEAr1340. Both
are based on ARM, Cortex A9 processor family.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
