commit 583d6b0062640def86f3265aa1042ecb6672516e upstream.
Reorder dma and dma-names property for serial node to make it compliant
with bindings.
Fixes: 6e8887f60f60 ("ARM: SPEAr13xx: Pass generic DW DMAC platform data from DT")
Signed-off-by: Kuldeep Singh <singh.kuldeep87k@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Link: https://lore.kernel.org/r/20220326042313.97862-3-singh.kuldeep87k@gmail.com'
Based on 1 normalized pattern(s):
the code contained herein is licensed under the gnu general public
license you may obtain a copy of the gnu general public license
version 2 or later at the following locations http www opensource
org licenses gpl license html http www gnu org copyleft gpl html
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 161 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de
The "dmas" cells for the designware DMA controller need to have only 3
properties apart from the phandle: request line, src master and
destination master. But the commit 6e8887f60f60 updated it incorrectly
while moving from platform code to DT. Fix it.
Cc: stable@vger.kernel.org # v3.10+
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
Switch to my kernel.org alias instead of a badly named gmail address,
which I rarely use.
PCIe configuration space should be passed through reg property, rather than
through ranges property. This patch does the correction for SPEAr13XX
SOCs.
Signed-off-by: Pratyush Anand <pratyush.anand@st.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Mohit Kumar <mohit.kumar@st.com>
This patch adds necessary DT nodes for pcie controllers and miphys for SPEAr13xx
SoCs.
SPEAr1310 has 3 PCIe ports and SPEAr1340 has 1, which are multiplexed with
ahci/sata pins. By default evaluation board of both controller works in ahci
mode. Because of this, these nodes are marked "disabled" by default.
In order to use pcie controller on evaluation boards do necessary modifications
on board and enable (By replacing "disabled" with "okay") pcie and miphy from
respective 'evb' dtsi file.
Phy specific initialization was previously done from spear1340.c, which isn't
required anymore as we have separate drivers for it. Remove it.
Signed-off-by: Mohit Kumar <mohit.kumar@st.com>
[viresh: fixed logs/cclist/checkpatch warnings, clubbed multiple patches into one]
Pull ARM SoC late cleanups from Arnd Bergmann:
"These are cleanups and smaller changes that either depend on earlier
feature branches or came in late during the development cycle. We
normally try to get all cleanups early, so these are the exceptions:
- A follow-up on the clocksource reworks, hopefully the last time we
need to merge clocksource subsystem changes through arm-soc.
A first set of patches was part of the original 3.10 arm-soc
cleanup series because of interdependencies with timer drivers now
moved out of arch/arm.
- Migrating the SPEAr13xx platform away from using auxdata for DMA
channel descriptions towards using information in device tree,
based on the earlier SPEAr multiplatform series
- A few follow-ups on the Atmel SAMA5 support and other changes for
Atmel at91 based on the larger at91 reworks.
- Moving the armada irqchip implementation to drivers/irqchip
- Several OMAP cleanups following up on the larger series already
merged in 3.10."
* tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
ARM: OMAP4: change the device names in usb_bind_phy
ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a
ARM: SPEAr: conditionalize SMP code
ARM: arch_timer: Silence debug preempt warnings
ARM: OMAP: remove unused variable
serial: amba-pl011: fix !CONFIG_DMA_ENGINE case
ata: arasan: remove the need for platform_data
ARM: at91/sama5d34ek.dts: remove not needed compatibility string
ARM: at91: dts: add MCI DMA support
ARM: at91: dts: add i2c dma support
ARM: at91: dts: set #dma-cells to the correct value
ARM: at91: suspend both memory controllers on at91sam9263
irqchip: armada-370-xp: slightly cleanup irq controller driver
irqchip: armada-370-xp: move IRQ handler to avoid forward declaration
irqchip: move IRQ driver for Armada 370/XP
ARM: mvebu: move L2 cache initialization in init_early()
devtree: add binding documentation for sp804
ARM: integrator-cp: convert use CLKSRC_OF for timer init
ARM: versatile: use OF init for sp804 timer
ARM: versatile: add versatile dtbs to dtbs target
This replaces an earlier patch from Viresh Kumar to move
the spear platform over to the generic DMA binding. This
version is now based on the merged multiplatform capable
spear platform, rather than the separate spear13xx/3xx/6xx
directories.
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Vinod Koul <vinod.koul@linux.intel.com>
Cc: devicetree-discuss@lists.ozlabs.org
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: spear-devel@list.st.com
Add gpio offset into "gpio-range-cells" property. It's used to support
sparse pinctrl range in gpio chip.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
This patch adds multiple device nodes for SPEAr machines and boards.
Signed-off-by: Bhavna Yadav <bhavna.yadav@st.com>
Signed-off-by: Deepak Sikri <deepak.sikri@st.com>
Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com>
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
Signed-off-by: Vijay Kumar Mishra <vijay.kumar@st.com>
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com>
This patch fixes existing DT support for all SPEAr SoC's. This includes:
- Removing few nodes from board files
- Updating DT data of few nodes
- Updating ranges of few busses
- Moving devices to correct parent bus
SPEAr platform provides a provision to control chipselects of ARM PL022 Prime
Cell spi controller through its system registers, which otherwise remains under
PL022 control which some protocols do not want.
This patch adds spics controller nodes in device tree for various SPEAr13xx
SoCs.
Cc: Linus Walleij <linus.walleij@linaro.org>
Reviewed-by: Vipin Kumar <vipin.kumar@st.com>
This patch adds plgpio nodes in SPEAr DT files.
viresh.kumar@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with viresh.linux@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'
Signed-off-by: Viresh Kumar <viresh.linux@gmail.com>
This patch adds machines/boards dts{i} files for SPEAr1310 and SPEAr1340. Both
are based on ARM, Cortex A9 processor family.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
