Based on 1 normalized pattern(s):
the code contained herein is licensed under the gnu general public
license you may obtain a copy of the gnu general public license
version 2 or later at the following locations http www opensource
org licenses gpl license html http www gnu org copyleft gpl html
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 161 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de
Switch to my kernel.org alias instead of a badly named gmail address,
which I rarely use.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
amba-pl011 driver supports two pin state "default" and "sleep" and it
expect from dt to provide this pinctrl states and phandler otherwise it
gives a warning message.
To remove this warning message pass default state with null phandler to uart
pins in device node (In our case all the pins are configured in default states
so we pass null phandler to pins).
Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com>
This patch enhances partition information of MTD devices like fsmc-nand and
spear-smi.
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
viresh.kumar@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with viresh.linux@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'
Signed-off-by: Viresh Kumar <viresh.linux@gmail.com>
arch/arm/mach-spear3xx/clock.c
arch/arm/mach-spear3xx/include/mach/generic.h
arch/arm/mach-spear3xx/include/mach/misc_regs.h
arch/arm/mach-spear3xx/spear320.c
arch/arm/mach-spear6xx/clock.c
arch/arm/mach-spear6xx/include/mach/misc_regs.h
Resolve even more merge conflicts.
This patch adds NOR partitions in all SPEAr boards dts files.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
Both SPEAr3xx and SPEAr6xx families have one instance of ARM PL080 DMA
controller. This patch adds in support for that.
This patch adds a generic target for SPEAr3xx machines that can be configured
via the device-tree. Currently the following devices are supported via the
devicetree:
- VIC interrupts
- PL011 UART
- PL061 GPIO
- PL110 CLCD
- SP805 WDT
- Synopsys DW I2C
- Synopsys DW ethernet
- ST FSMC-NAND
- ST SPEAR-SMI
- ST SPEAR-KEYBOARD
- ST SPEAR-RTC
- ARASAN SDHCI-SPEAR
- SPEAR-EHCI
- SPEAR-OHCI
Other peripheral devices will follow in later patches.
This also removes IO_ADDRESS macro and creates 16 MB static mappings instead of
4K for individual peripherals. This is done to have efficient TLB lookup for any
I/O windows that are located closely together. ioremap() on this range will
return this mapping only instead of creating another.
