path: root/arch/arm/boot/dts/spear3xx.dtsi
2015-07-17Update Viresh Kumar's email addressViresh Kumar
Switch to my kernel.org alias instead of a badly named gmail address, which I rarely use. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-23ARM: dts: spear: cpus/cpu nodes dts updatesLorenzo Pieralisi
This patch updates the in-kernel dts files according to the latest cpus and cpu bindings updates for ARM. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Update device nodesShiraz Hashim
This patch adds multiple device nodes for SPEAr machines and boards. Signed-off-by: Bhavna Yadav <bhavna.yadav@st.com> Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vijay Kumar Mishra <vijay.kumar@st.com> Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Modify DT bindings for STMMACDeepak Sikri
This patch modifies the DT bindings for the GMAC IP existings for the SPEAr family. The DT bindings now additionally pass the phy mode as a configuration parameter for the ethernet device. Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Fix existing DT supportVipul Kumar Samar
This patch fixes existing DT support for all SPEAr SoC's. This includes: - Removing few nodes from board files - Updating DT data of few nodes - Updating ranges of few busses - Moving devices to correct parent bus Signed-off-by: Bhavna Yadav <bhavna.yadav@st.com> Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vijay Kumar Mishra <vijay.kumar@st.com> Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-06-20Viresh has movedViresh Kumar
viresh.kumar@st.com email-id doesn't exist anymore as I have left the company. Replace ST's id with viresh.linux@gmail.com. It also updates .mailmap file to fix address for 'git shortlog' Signed-off-by: Viresh Kumar <viresh.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-12SPEAr: Add DT bindings for SPEAr's timerViresh Kumar
All SPEAr SoC's use ST's Timer module. This patch adds device tree probing capability for that. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-04-22SPEAr: Add PL080 DMA support for 3xx and 6xxViresh Kumar
Both SPEAr3xx and SPEAr6xx families have one instance of ARM PL080 DMA controller. This patch adds in support for that. Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
2012-04-22ARM: SPEAr3xx: Add device-tree support to SPEAr3xx architectureViresh Kumar
This patch adds a generic target for SPEAr3xx machines that can be configured via the device-tree. Currently the following devices are supported via the devicetree: - VIC interrupts - PL011 UART - PL061 GPIO - PL110 CLCD - SP805 WDT - Synopsys DW I2C - Synopsys DW ethernet - ST FSMC-NAND - ST SPEAR-SMI - ST SPEAR-KEYBOARD - ST SPEAR-RTC - ARASAN SDHCI-SPEAR - SPEAR-EHCI - SPEAR-OHCI Other peripheral devices will follow in later patches. This also removes IO_ADDRESS macro and creates 16 MB static mappings instead of 4K for individual peripherals. This is done to have efficient TLB lookup for any I/O windows that are located closely together. ioremap() on this range will return this mapping only instead of creating another. Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
