This converts the Nomadik pin controller and all associated device
trees to use the standard, generic config bindings for pin controllers.
There are no such device trees deployed in the wild so this is
safe to do to set a good example.
trees to use the standard, generic mux bindings for pin controllers.
This moves some of the pin setup related to the CW1200 WLAN
module over to the device tree. As the driver is not yet
activated for the CW1200 WLAN we do not assign this pinctrl
state to any device node yet.
Get rid of the cmdline argument passing of a certain U9500
platform variant, as this is not supported by the kernel or
any device tree.
This moves the SKE keypad pin control table out of the board
file and into the device tree. This was previously set to be
active on all MOP500 and HREF boards but after reading the
schematic this seems incorrect: the HREFv60 and later uses
one of these for MC5 and no reference designs have the SKE
connected to any hardware so just leave the pins alone
in the power-on state.
This moves the MCDE pin control table out of the board file
and into the device tree. Some pins and configs have been
marked as used by sub-devices or slaves to the MCDE, such
as I2C device 0-070 which is the HDMI interface circuit
AV8100, but the pins rather belong to the MCDE SOC block
as they come out of the main ASIC. The touch screen GPIO
is not related to MCDE so this gets deleted and need to
be tied to the respective touch screen (I2C) device
once that device is added instead.
This moves the SPI pin control table out of the board file
and into the device tree. Move the specific setting for
SSP0 on the HREFprev60 into the prev60-specific DTS file.
The SPI2 configuration is not really connected to any device,
as it will conflict with GPIO218 which is used on all HREFs.
This moves the MUSB pin control table out of the board file
and into the device tree. Tie the config to the on-chip MUSB
device rather than the ab8500-usb device which is off-chip.
This moves the static, device-tied pin control configuration
out of the board file board-mop500-pins.c and into the device
tree. Add nodes for MSP0 and MSP2 on the HREF and Snowball
so we can reference the pins properly.
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Patrice Chotard <patrice.chotard@st.com>
tree. Add entries for SDI1 and SDI2 on the Snowball so that the
WLAN pins on SDI1 can be used further on, and the unused pins
on SDI2 can be put to sleep.
tree. Define possible states also for I2C4 even if it's not
used by any board file at this time.
tree.
We create a new .dtsi-file to be shared between all the
MOP500-related boards, that include all HREF variants and
the Snowball board. Assign pin states for HREF and Snowball
boards alike.
