Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This adds the TPG110 TDO43MTEA2 24-bit RGB LCD panel and sets
up the Nomadik device tree to activate the CLCD and connect it
to this panel.
This adds the STMPE PWM to the NHK15 device tree.
The LIS3LV02DL accelerometer on the Nomadik NHK15 can generate
IRQs by the DRDY line. Map this in the DTS file and set up the
pin as input to the SoC.
The two Nomadik variants have the accelerometer mounted on
different I2C lines. Push the definition down to the top-level
board DTS files to get things right.
The S8815 board is using RX/TX on UART0, and the NHK8815 is
using RX/TX and CTS/RTS (the latter connected to a Bluetooth
chip). Activate the right groups with the u0 UART0 function
on each board and undisable it. Get rid of the old erroneous
default definition from the SoC file.
Instead of introducing a board-specific DT node for biasing the
MMC/SD and SATA ports, use the new device tree hogs.
The UART0 is not used on these boards, yet active and blocking
other use. Fix this by disabling UART0 and setting port aliases
to maintain port enumeration to userspace.
We altered the device tree bindings for the Nomadik family of
pin controllers to be standard, this file was merged out-of-order
so we missed fixing this. Fix it up.
This adds a device tree for the Nomadik NHK15 development kit
board.
