This moves over the configuration of the GPIO keys (used for
proximity sensor and Hall effect sensor) from the static pin
configuration file to the device tree. As part of the exercise,
implement the GPIO keys properly in a per-UIB file as this
setup actually differs with each UIB.
This moves the SKE keypad pin control table out of the board
file and into the device tree. This was previously set to be
active on all MOP500 and HREF boards but after reading the
schematic this seems incorrect: the HREFv60 and later uses
one of these for MC5 and no reference designs have the SKE
connected to any hardware so just leave the pins alone
in the power-on state.
This moves the SPI pin control table out of the board file
and into the device tree. Move the specific setting for
SSP0 on the HREFprev60 into the prev60-specific DTS file.
The SPI2 configuration is not really connected to any device,
as it will conflict with GPIO218 which is used on all HREFs.
This moves the MUSB pin control table out of the board file
and into the device tree. Tie the config to the on-chip MUSB
device rather than the ab8500-usb device which is off-chip.
This moves the input-pulled-up setting for GPIO217 as used
on the HREFs prior to v60 from the boardfile to the device
tree. GPIO218 is only used with the TVK UIB so move it to
that .dtsi file.
This moves the static, device-tied pin control configuration
out of the board file board-mop500-pins.c and into the device
tree. Add entries for SDI1 and SDI2 on the Snowball so that the
WLAN pins on SDI1 can be used further on, and the unused pins
on SDI2 can be put to sleep.
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Patrice Chotard <patrice.chotard@st.com>
This patch adds pinctrl device tree settings for uart0 and uart2
for ccu8540 board.
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com>
