git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control changes from Linus Walleij:
"Here is a stash of pin control changes I have collected for the v3.19
series. Mainly new hardware support, with Intels new embedded SoC as
the especially interesting thing standing out, fully using the
subsystem.
- Force conversion of the ux500 pin control device trees and parsers
to use the generic pin control bindings.
- New driver and device tree bindings for the Qualcomm PMIC MPP pin
controller and GPIO.
- Some ACPI infrastructure for pin controllers.
- New driver for the Intel CherryView/Braswell pin controller, the
first Intel pin controller to fully take advantage of the pin
control subsystem.
- Support the Freescale i.MX VF610 variant.
- Support the sunxi A80 variant.
- Support the Samsung Exynos 4415 and Exynos 7 variants.
- Split out Intel pin controllers to their own subdirectory.
- A large slew of rockchip pin control updates, including
suspend/resume support.
- A large slew of Samsung Exynos pin controller updates.
- Various minor updates and fixes"
* tag 'pinctrl-v3.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (49 commits)
pinctrl: at91: enhance (debugfs) at91_gpio_dbg_show
pinctrl: meson: add device tree bindings documentation
gpio: tz1090: Fix error handling of irq_of_parse_and_map
pinctrl: tz1090-pinctrl.txt: Fix typo in binding
pinctrl: pinconf-generic: Declare dt_params/conf_items const
pinctrl: exynos: Add support for Exynos4415
pinctrl: exynos: Add initial driver data for Exynos7
pinctrl: exynos: Add irq_chip instance for Exynos7 wakeup interrupts
pinctrl: exynos: Consolidate irq domain callbacks
pinctrl: exynos: Generalize the eint16_31 demux code
pinctrl: samsung: Separate per-bank init and runtime data
pinctrl: samsung: Constify samsung_pin_ctrl struct
pinctrl: samsung: Constify samsung_pin_bank_type struct
pinctrl: samsung: Drop unused label field in samsung_pin_ctrl struct
pinctrl: samsung: Make samsung_pinctrl_get_soc_data use ERR_PTR()
pinctrl: Add Intel Cherryview/Braswell pin controller support
gpio / ACPI: Add knowledge about pin controllers to acpi_get_gpiod()
pinctrl: Fix path error in documentation
pinctrl: rockchip: save and restore gpio6_c6 pinmux in suspend/resume
pinctrl: rockchip: add suspend/resume functions
The SoC file defines the location and type of the ethernet
adapter, this should be in the per-board file, as it is by no
means necessary to have an ethernet adapter connected to this
memory space.
The idea to use two GPIO pins for bit-banged I2C is an S8815
pecularity, so move this over to the board-specific file and
out of the SoC core DTSI file.
This pushes the setting of the card detect GPIO pin down into
the top-level file for the board, since it is not a property of
the ASIC (which this DTSI is about) but a property of the board
design.
This converts the Nomadik pin controller and all associated device
trees to use the standard, generic config bindings for pin controllers.
There are no such device trees deployed in the wild so this is
safe to do to set a good example.
The GPIO pin connected to card detect was inverted twice: once by
the argument to the GPIO line itself where it was magically marked
as active low by the flag GPIO_ACTIVE_LOW (0x01) in the third cell,
and also marked active low AGAIN by explicitly stating
"cd-inverted" (a deprecated method).
After commit 78f87df2b4f8760954d7d80603d0cfcbd4759683
"mmc: mmci: Use the common mmc DT parser" this results in the
line being inverted twice so it was effectively uninverted, while
the old code would not have this effect, instead disregarding the
flag on the GPIO line altogether, which is a bug. I admit the
semantics may be unclear but inverting twice is as good a
definition as any on how this should work.
So fix up the buggy device tree. Use proper #includes so the DTS
is clear and readable.
Cc: Ulf Hansson <ulf.hansson@linaro.org>
We used to set up the GPIO used for the SMC ethernet IRQ by
requesting the GPIO line explicitly. As we recently established
that specifying the GPIO controller as interrupt parent and
requesting one of its interrupts by reference should be enough,
we do away with this. Incidentally, the Nomadik GPIO chip driver
handles this just fine: the IRQ is set up and fired as expected.
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-nomadik into next/dt
From Linus Walleij:
Nomadik DT and clock work:
- Lee Jones' pinctrl compat ontology patches
- A real clock driver for the Nomadik, 100% DT-based
- Device tree changes for the Nomadik clocks
* tag 'nomadik-dt-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-nomadik:
ARM: nomadik: add the new clocks to the device tree
clk: nomadik: implement the Nomadik clocks properly
pinctrl/nomadik: Standardise Pinctrl compat string for Nomadik based platforms
ARM: nomadik: Standardise Nomadik STN8815 based Pinctrl compat string in the DTS
arch/arm/boot/dts/ste-nomadik-s8815.dts
This revamps the device tree to fit with the new clock
implementation and brings it quite a bit closer to how
the hardware actually works.
After this the clock implementation knows about all
clock gates and will gate off all unused clocks at
boot time and save a bit of power.
From Linus Walleij:
Device tree patches for the Nomadik machine:
- Move clock registration to the device tree
- Support probing the MTU timer from the device tree
- Register user LED and user key in the device tree
- Update defconfig to account for user LED and user key
- Move pin control mappings to the device tree
* tag 'nomadik-dt-for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-nomadik:
ARM: nomadik: move the pin configuration to DT
ARM: nomadik: add led and key for S8815
ARM: nomadik: register clocksource from device tree
ARM: nomadik: convert all clocks except timer to dt
clocksource: nomadik-mtu: support of probe
This moves the pin configuration for the Nomadik over to the
device tree using Gabriel's bindings. Remove the auxdata
nailing down the name of the pin controller as this is no
longer necessary.
Cc: Gabriel Fernandez <gabriel.fernandez@st.com>
Cc: Patrice Chotard <patrice.chotard@st.com>
This adds device tree hunks for the LED and userbutton on the
USB S8815 board, and set up a heartbeat trigger on the LED and
an escape key on the user button. Alter the defconfig to enable
these standard DT-enabled GPIO drivers.
The assignment of IRQ for the SMC91x ethernet adapter had two
problems making it non-working:
- It was not put into the ethernet device node. Let's do this
by using the board-specific overlay, so we can make other
overlays on other Nomadik boards.
- The IRQ number was actually completely wrong, this was the
number for NHK8815, not S8815.
After this ethernet starts working on the USB S8815.
This moves over the MMC/SD card support to the device tree probe
path. The special GPIO to bias the card detect line is kept,
but the pin property is moved to the device tree as part of
the MMC/SD card node.
This converts the SMSC91x ethernet controller to use device
tree. The existing solution from the board file, to request the
GPIO triggering the ethernet IRQ from the board file is kept
for the time being, but the GPIO number assignment is moved
over to the device tree.
Support basic device tree boot on the Nomadik. Implement the
support in the cpu file with the intent of deleting the board
files later. At this stage IRQ controllers, system timer,
l2x0 cache, UARTs and thus console boot is fully functional.
Patch out the code adding devices by initcalls for now so
as not to disturb the boot.
