path: root/arch/arm/boot/dts/stih410-b2120.dts
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-05Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree updates from Arnd Bergmann: "This is the usual set of changes for device trees, with over 700 non-merged changesets. There is an ongoing set of dtc warning fixes and the usual bugfixes, cleanups and added device support. The most interesting bit as usual is support for new machines listed below: - The Allwinner H6 makes its debut with the Pine-H64 board, and we get two new machines based on its older siblings: the H5 based OrangePi Zero+ and the A64 based Teres-I Laptop from Olimex. On the 32-bit side, we add The Olimex som204 based on Allwinner A20, and the Banana Pi M2 Zero development board (based on H2). - NVIDIA adds support for Tegra194 aka "Xavier", plus their p2972 development board and p2888 CPU module. - The Nuvoton npcm750 is a BMC that was newly added, for now we only support running on the evaluation board. - STmicroelectronics stm32 gains support for the stm32mp157c and two evaluation boards. - The Toradex Colibri board family grows a few members based on the i.MX6ULL variant. - The Advantec DMS-BA16 is a Qseven module using the NXP i.MX6 family of chips. - The Phytec phyBOARD Mira is a family of industrial boards based on i.MX6. For now, four models get added. - TI am335x based PDU-001 is an industrial embedded machine used for traffic monitoring - The Aspeed platform now supports running on the BMC on the Qualcomm Centriq 2400 server - Samsung Exynos4 based Galaxy S3 is a family of mobile phones Qualcomm msm8974 based Galaxy S5 is a rather different phone made by the same company. - The Xilinx Zynq and ZynqMP platforms now gained a lot of dts file for the various boards made by Xilinx themselves, as well as the Digilent Zybo Z7. - The ARM Versatile family now supports the "IB2" interface board. - The Renesas H2 based "Stout" and the H3 based Salvator-X are more evaluation boards named after a kind of beer, as most of them are. The r8a77980 (V3H) based "Condor" apparently doesn't follow that tradition. ;-) - ROC-RK3328-CC is a simple developement board from the Libre Computer Project, based on the Rockchips RK3328 SoC - Haiku is another development board plus Qseven module based on Rockchips RK3368 and made by Theobroma Systems" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (701 commits) arm: dts: modify Nuvoton NPCM7xx device tree structure arm: dts: modify Makefile NPCM750 configuration name arm: dts: modify clock binding in NPCM750 device tree arm: dts: modify timer register size in NPCM750 device tree arm: dts: modify UART compatible name in NPCM750 device tree arm: dts: add watchdog device to NPCM750 device tree arm64: dts: uniphier: add ethernet node for PXs3 ARM: dts: uniphier: add pinctrl groups of ethernet for second instance arm: dts: kirkwood*.dts: use SPDX-License-Identifier for board using GPL-2.0+ arm: dts: kirkwood*.dts: use SPDX-License-Identifier for boards using GPL-2.0+/MIT arm: dts: kirkwood*.dts: use SPDX-License-Identifier for boards using GPL-2.0 arm: dts: armada-385-turris-omnia: use SPDX-License-Identifier arm: dts: armada-385-db-ap: use SPDX-License-Identifier arm: dts: armada-388-rd: use SPDX-License-Identifier arm: dts: armada-xp-db-xc3-24g4xg: use SPDX-License-Identifier arm: dts: armada-xp-db-dxbc2: use SPDX-License-Identifier arm: dts: armada-370-db: use SPDX-License-Identifier arm: dts: armada-*.dts: use SPDX-License-Identifier for most of the Armada based board arm: dts: armada-xp-98dx: use SPDX-License-Identifier for prestara 98d SoCs arm: dts: armada-*.dtsi: use SPDX-License-Identifier for most of the Armada SoCs ...
2018-03-14ARM: dts: STi: Remove "console=ttyASN" from bootargs for STi boardsPatrice Chotard
As serial interface is already specified into stdout-path property, "console=ttyASN,115200" from bootargs can be removed. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-14ARM: dts: STi: Fix aliases property name for STi boardsPatrice Chotard
Update serial aliases from "ttyASN" to more common "serialN". Since dtc v1.4.6-9-gaadd0b65c987, aliases property name must be lowercase only. This allows to fix following dtc warnings: arch/arm/boot/dts/stih418-b2199.dtb: Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-' arch/arm/boot/dts/stih407-b2120.dtb: Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-' arch/arm/boot/dts/stih410-b2260.dtb: Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-' arch/arm/boot/dts/stih410-b2120.dtb: Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-' Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-07arm: dts: replace 'linux,stdout-path' with 'stdout-path'Rob Herring
'linux,stdout-path' has been deprecated for some time in favor of 'stdout-path'. Now dtc will warn on occurrences of 'linux,stdout-path'. Search and replace all the of occurrences with 'stdout-path'. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-02-12ARM: dts: STi: Add fake reg property for usb2_picophyX nodesPatrice Chotard
Add fake reg property for usb2_picophy nodes. This allows to fix the following warning when compiling dtb with W=1 option : arch/arm/boot/dts/stih410-b2120.dtb: Warning (simple_bus_reg): Node /soc/phy2 missing or empty reg/ranges property arch/arm/boot/dts/stih410-b2120.dtb: Warning (simple_bus_reg): Node /soc/phy3 missing or empty reg/ranges property arch/arm/boot/dts/stih410-b2120.dtb: Warning (simple_bus_reg): Node /soc/phy2 missing or empty reg/ranges property arch/arm/boot/dts/stih410-b2120.dtb: Warning (simple_bus_reg): Node /soc/phy3 missing or empty reg/ranges property arch/arm/boot/dts/stih418-b2199.dtb: Warning (simple_bus_reg): Node /soc/phy2 missing or empty reg/ranges property arch/arm/boot/dts/stih418-b2199.dtb: Warning (simple_bus_reg): Node /soc/phy3 missing or empty reg/ranges property Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-02-12ARM: dts: STi: Add fake reg property for sti-display-subsystemPatrice Chotard
As sti-display-subsystem sub-nodes (sti-compositor, sti-tvout sti-hdmi, sti-hda and sti-hqvdp) are SoC's IP, we add a fake reg property. This allows to fix the following warning when compiling dtb with W=1 option: arch/arm/boot/dts/stih410-b2120.dtb: Warning (unit_address_vs_reg): Node /soc/sti-display-subsystem/sti-hda@8d02000 has a unit name, but no reg property Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-02-12ARM: dts: STi: Fix bindings notationPatrice Chotard
Remove leading 0x and 0s from bindings notation Add missing unit-address and remove some which are useless. This allows to fix several warnings like : Warning (unit_address_vs_reg): Node XXXX has a reg or ranges property, but no unit name Warning (simple_bus_reg): Node XXXX simple-bus unit address format error, expected "123456" Warning (unit_address_vs_reg): Node XXXX has a unit name, but no reg property Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-20arm: dts: fix unit-address leading 0sRob Herring
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using the following command: perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*' Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some occurrences of uppercase hex. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-01-11ARM: dts: STiH410-B2120: enable sti-hda at board levelPatrice Chotard
As sti-hda is only available on STiH410-B2120, disable it in STiH410.dtsi and enable it at board level. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2015-10-15ARM: dts: Enable Ethernet on STi's B2120 boardsMaxime Coquelin
These boards are mounted with Realtek RTL8367 switch. We consider the bootloader will have intiliazed the switch before jumping into the kernel, so we declare it as a fixed link. Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
2015-09-29ARM: dts: stih410: Enable USB2.0 and related PHY nodes at board levelMaxime Coquelin
A board might not expose the USB2.0 ports, so disable them by default in SoC file, and enable them in b2120 board. Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Peter Griffin <peter.griffin@linaro.org> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
2015-04-30ARM: STi: DT: STiH407: Add dt nodes for sdhci and emmc.Peter Griffin
The nodes have been split to allow as much commonality as possible. The stih407 has a silicon bug with eMMC UHS modes (with top regs) and as such doesn't have any of the uhs dt properties. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
2014-11-18ARM: STi: DT: STih407: STih410: Add clk_ignore_unused to kernel bootargsPeter Griffin
At the moment we don't take a reference on some core interconnect clocks which means when CCF turns off unused clocks the SoC will hang. As a temp soltuion we will boot with clk_ignore_unused parameter for all b2120 boards. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
2014-11-18ARM: STi: DT: STiH410: Add STiH410 SoC and b2120 board support.Peter Griffin
The STiH410 is an advanced multi-HD AVC processor with 3D graphics acceleration and 1.5-GHz ARM Cortex-A9 SMP CPU part of the stih407 family. It has wide connectivity including USB 3.0, PCI-e, SATA and gigabit ethernet. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
