Change cs-gpio to cs-gpios.
Signed-off-by: Loic Pallardy <loic.pallardy@st.com>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
This allows to make the board boot even if clock handling
by all drivers is not properly done.
Reported-by: Peter Griffin <peter.griffin@linaro.org>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Allow to use the mico USB port which is driven by USB3 IP
B2260 board is the STMicroelectronics 96Board
based on STiH410 soc :
- 1GB DDR
- On-Board USB combo WiFi/Bluetooth RTL8723BU
with PCB soldered antenna
- Ethernet 1000-BaseT
- Sata
- HDMI
- 2 x USB2 type A
- micro USB2 type AB
- SD card slot
- High speed connector (SD/I2C/USB interfaces)
- Slow speed connector (UART/I2C/GPIO/SPI/PCM interfaces)
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Reviewed-by: Peter Griffin <peter.griffin@linaro.org>
