commit 7ac1f59c09a61e6af6622df6809e003b0af07f3d upstream.
The GPIO polarity is missing in the hdmi,hpd-gpio property, this
fixes the following DT warnings:
arch/arm/boot/dts/stih410-b2120.dtb: Warning (gpios_property): hdmi,hpd-gpio property
size (8) too small for cell size 2 in /soc/sti-display-subsystem/sti-hdmi@8d04000
arch/arm/boot/dts/stih407-b2120.dtb: Warning (gpios_property): hdmi,hpd-gpio property
arch/arm/boot/dts/stih410-b2260.dtb: Warning (gpios_property): hdmi,hpd-gpio property
[arnd: marked Cc:stable since this warning shows up with the latest dtc
by default, and is more likely to actually cause problems than the
other patches from this series]
Cc: stable@vger.kernel.org
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
[ Upstream commit b9ec866d223f38eb0bf2a7c836e10031ee17f7af ]
The clock parent was lower than child clock which is not correct.
In some use case, it leads to division by zero.
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com>
Pull ARM DT updates from Arnd Bergmann:
"These are as usual a very large number of mostly boring updates to
enable devices in existing machines, or to fix minor bugs. Notably, an
ongoing treewide effort to fix warnings caused by an update to the
device tree compiler. These are enabled with "make W=1" at the moment
but can hopefully become the default once all issues have been
addressed.
No new SoC platform is added this time around (Armada 395 and Orion
mv88f5181 are slight variations of existing ones), but a significant
number of new dts files are added, which I list by platform:
- Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets,
Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite,
Olimex A33-Olinuxino, and Nano Pi Neo single-board computers
- ARM Realview: all supported machines (ported from board files)
- Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and
BCM958622hr reference boards for Northstar platform, Raspberry Pi
Zero single-board computer
- Marvell EBU: Netgear WNR854T router (ported from board file),
Armada 395 SoC platform and GP board Armada 390 DB development
board
- NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x
single-board computer, Technologic Systems TS-4900 and Engicam
IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board
- Qualcomm: LG Nexus 5 Phone
- Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards
- Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288
Reload platform
- ST Microelectronics STi: B2260 (96boards) single-board computer
- TI Davinci: OMAP-L138 LCDK Development kit
- TI OMAP: beagleboard-x15 rev B1 single-board computer"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits)
ARM: dts: sony-nsz-gs7: add missing unit name to /memory node
ARM: dts: chromecast: add missing unit name to /memory node
ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node
ARM: dts: berlin2: Add missing unit name to /soc node
ARM: dts: berlin2cd: Add missing unit name to /soc node
ARM: dts: berlin2q: Add missing unit name to /soc node
ARM: dts: berlin2: Remove skeleton.dtsi inclusion
ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion
ARM: dts: berlin2q: Remove skeleton.dtsi inclusion
arm: dts: berlin2q: enable all wdt nodes unconditionally
arm: dts: berlin2: enable all wdt nodes unconditionally
ARM: dts: omap5-igep0050.dts: Use tabs for indentation
ARM: dts: Fix igepv5 power button GPIO direction
ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node
ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes
ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
It is necessary to properly configure these clocks in order
to address 720p and 1080p HDMI resolution.
Signed-off-by: Vincent Abriou <vincent.abriou@st.com>
Acked-by: Peter Griffin <peter.griffin@linaro.org>
Add the hva (multi-format video encoder for STMicroelectronics SoC)
dt nodes for the hva device, defining register address, interrupt
and clock.
Signed-off-by: Jean-Christophe TROTIN <jean-christophe.trotin@st.com>
The STiH4{07,10} platform contains some interconnect clocks which are used
by various IPs. If this clock isn't handled correctly by ST's EHCI/OHCI
drivers, their hub won't be found, the following error be shown and the
result will be non-working USB:
[ 97.221963] hub 2-1:1.0: hub_ext_port_status failed (err = -110)
Tested-by: Peter Griffin <peter.griffin@linaro.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
[Lee: Changed node name and added the unit address]
Reviewed-by: Peter Griffin <peter.griffin@linaro.org>
https://git.kernel.org/pub/scm/linux/kernel/git/mcoquelin/sti into next/dt
Merge "STi DT changes for v4.4, round 1" from Maxime Coquelin:
Highlights:
- Add multiple pinctrl configurations to STiH407
- Enable devices using pins only at board level
- Add HW RNG device nodes to STiH407 family
- Fix MMC0 clock configuration on STiH418
- Fix interrupt related bindings on STiH407
* tag 'sti-dt-for-v4.4-1' of https://git.kernel.org/pub/scm/linux/kernel/git/mcoquelin/sti:
ARM: STi: STiH407: Enable the 2 HW Random Number Generators for STiH4{07, 10}
ARM: DT: STi: STiH418: Fix mmc0 clock configuration
ARM: STi: DT: STiH407: Rename incorrect interrupt related binding
ARM: STi: STiH407: Add spi default pinctrl groups.
ARM: DT: STiH407: Add RMII pinctrl support
ARM: DT: STiH407: Add pinconfig for IRB UHF and IRB TX
ARM: DT: STiH407: Add SD pinctrl config for mmc0 controller
ARM: DT: STiH407: Add systrace pin configuration
ARM: DT: STiH407: Add NAND flash controller pin configuration
ARM: DT: STiH407: Add SPI FSM (NOR Flash) Controller pin config
ARM: DT: STiH407: Add serial3 pinctrl configuration
ARM: DT: STiH407: Add SPI 3 wire and 4 wire pinctrl configs
ARM: STi: DT: STiH407: Add i2c3 alternate pin configs
ARM: STi: DT: STiH407: Add a cec0 pin definition
ARM: dts: stih410: Enable USB2.0 and related PHY nodes at board level
ARM: dts: stih407/410: Tidy up display nodes
ARM: dts: stih407: Enable PWM nodes only board level
A board might not expose the USB2.0 ports, so disable them by default in SoC
file, and enable them in b2120 board.
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
The display nodes are common to both STiH407 and STiH410, move them to the
family file.
STI drm drivers probe and bind using component framework was incorrect.
In addition to drivers fix DT update is needed to make all sub-components
become childs of sti-display-subsystem.
Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Add the bdisp (2D blitter for STMicroelectronics SoC) dt nodes for the
first of the two bdisp devices, defining register address, interrupt and
clock.
Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com>
This patch adds the DRM/KMS dt nodes.
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@linaro.org>
This patch adds the DT nodes for the extra ehci and ohci usb controllers
on the stih410 SoC.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
This patch adds the dt nodes for the extra usb2 picophys found on
the stih410.
These two picophys are used in conjunction with the extra ehci/ohci usb
controllers also found on the stih410 SoC.
The STiH410 is an advanced multi-HD AVC processor with 3D graphics acceleration
and 1.5-GHz ARM Cortex-A9 SMP CPU part of the stih407 family.
It has wide connectivity including USB 3.0, PCI-e, SATA and gigabit ethernet.
