Signed-off-by: Lee Jones <lee.jones@linaro.org>
By popular vote, the DT binding includes for reset controllers are located
in include/dt-bindings/reset/. Move the STi reset constants in there, too,
to avoid confusion.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
This driver is used to enable System Configuration Register controlled
External, CTI (Core Sight), PMU (Performance Management), and PL310 L2
Cache IRQs prior to use.
Here we are enabling PMU IRQs on both channels.
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
This is ARM's generic Performance Monitoring Unit.
Supply top level nodes for the STiH416 based development boards.
The Pinctrl configuration has already been applied, so the only
missing piece of the DT puzzle is for a board's DTB to enable
the nodes.
Signed-off-by: Ajit Pal Singh <ajitpal.singh@st.com>
Now there are generic phy type constants declared in phy.h, migrate over to
using them rather than defining our own. This change has been done as one
atomic commit to be bisectable.
Note: The values of the defines are the same, so there is no ABI breakage
with this patch.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Based on Arnds review comments here https://lkml.org/lkml/2014/11/13/161,
we should not be mixing address spaces in the reg property like this driver
currently does. This patch updates the driver, dt docs and also the existing
dt nodes to pass the sysconfig offset in the syscon dt property.
This patch breaks DT compatibility! But this platform is considered WIP,
and is only used by a few developers who are upstreaming support for it.
This change has been done as a single atomic commit to ensure it is
bisectable.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
update the miphy365 phy driver to access sysconfig register offsets via
syscfg dt property.
This is because the reg property should not be mixing address spaces
like it does currently for miphy365. This change then also aligns us
to how other platforms such as keystone and bcm7445 pass there syscon
offsets via DT.
This patch breaks DT compatibility, but this platform is considered WIP,
bisectable.
Following Arnds review comments, update the miphy365 to follow the
common convention of naming the phy node names as phy@addr.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
This patch adds the DT nodes for the 4 usb ehci and ohci usb controllers
on the stih416 SoC.
This usb picophy is found on stih415/6 SoC.
ARM: DT: STi: STiH416: Add DT node for ST's SATA device
Cc: devicetree@vger.kernel.org
Acked-by: Alexandre Torgue <alexandre.torgue@st.com>
The MiPHY365x is a Generic PHY which can serve various SATA or PCIe
devices. It has 2 ports which it can use for either; both SATA, both
PCIe or one of each in any configuration.
Acked-by: Mark Rutland <mark.rutland@arm.com>
We supply two of these. The first is controlled by the System Configuration
registers and the second one provided is a more traditional 'memory mapped'
variant. Each are handled by they own sub-driver.
This patch adds device tree config for both sdhci controllers
on the stih416 SoC.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
This patch fixes two problems: -
1) The device tree isn't currently providing sti-ethclk which is
required by the dwmac glue code to correctly configure the ethernet
PHY clock speed.
This means depending on what the bootloader/jtag has
configured this clock to, and what switch/hub the board is plugged
into you most likely will NOT successfully negotiate a ethernet link.
2) The stmmaceth clock was associated with the wrong clock. It was
referencing the PHY clock rather than the interconnect clock which
clocks the IP.
This patch also brings us closer to not having to boot the upstream
kernel with the clk_ignore_unused parameter.
Patch adds DT entries for clockgen A0/1/10/11/12
Signed-off-by: Pankaj Dev <pankaj.dev@st.com>
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@linaro.org>
all-caps node name is not very usual.
Add keyscan support for stih416.
It is disabled by default given that it is not enabled on all boards.
Also there are PIOs conflict with already claimed lines.
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Signed-off-by: Giuseppe Condorelli <giuseppe.condorelli@st.com>
Here we add the necessary device nodes required for successful device
probing and Pinctrl setup for the FSM when booting on an STiH416 (Orly2).
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Acked-by Angus Clark <angus.clark@st.com>
Acked-by: Brian Norris <computersforpeace@gmail.com>
This patch adds IRB support to STiH416 platforms.
Tested on B2000 and B2020 development board
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
This patch adds support to STiH416 SOC, which has two ethernet
snps,dwmac controllers version 3.710. With this patch B2000 and B2020
boards can boot with ethernet in MII and RGMII modes.
Tested on both B2020 and B2000.
This patch adds soft reset controller support for STiH415 and adds new
softreset lines required for other device tree nodes in the header file.
This patch adds a reset controller node to the SOC device tree and also
adds new header files with reset lines required for other device tree
nodes.
This patch supplies I2C configuration to STiH416 SoC.
This patch fixes a bug in pinctrl setup of serial2 device, Some of the
pins in the pinctrl node of serial2 do not belong to that
pin-controller. This patch divides them in the pins into there
respective pin controller nodes.
Without this patch serial on StiH416-B2000 Board will not work as it
fails with:
"st-pinctrl pin-controller-rear.3: failed to get pin(99) name
st-pinctrl pin-controller-rear.3: maps: function serial2 group serial2-0
num 4
pinconfig core: failed to register map default (3): no group/pin given"
The STiH416 is advanced HD AVC processor with 3D graphics acceleration
and 1.2-GHz ARM Cortex-A9 SMP CPU.
CC: Stephen Gallimore <stephen.gallimore@st.com>
CC: Stuart Menefy <stuart.menefy@st.com>
CC: Arnd Bergmann <arnd@arndb.de>
CC: Linus Walleij <linus.walleij@linaro.org>
