Since v4.8, STiH415/416 clock support has
been removed [1], these platform doesn't boot.
We can remove DTS files related to these socs.
[1] https://patchwork.kernel.org/patch/9157571/
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
- Remove useless gpio-cells
- Update second parameter by using GPIO_ACTIVE_HIGH/LOW
instead of hardcoded value
Because the first sdhci controller is present on both stih415 and
stih416 SoC which can both populate the b2020 board, it can be
enabled in the generic DT file.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
Suggested-by: Olof Johansson <olof@lixom.net>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Interconnect clocks are not yet managed at the init, then
we have to start the kernel with clk_ignore_unused.
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@linaro.org>
Here we add the necessary device nodes required for successful device
probing and Pinctrl setup for the FSM when booting on an STiH415 (Orly1)
or STiH416 (Orly2) based b2020 development board.
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Acked-by Angus Clark <angus.clark@st.com>
Acked-by: Brian Norris <computersforpeace@gmail.com>
This patch adds support to STiH415 SOC, which has two ethernet
snps,dwmac controllers version 3.610. With this patch B2000 and B2020
boards can boot with ethernet in MII and RGMII modes.
Tested on both B2020 and B2000.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
This patch supplies I2C configuration to B2000 and B2020
based on either STiH415 or STiH416 SoCs.
B2020 ADI board is reference board for STIH415/416 SOCs, it has 2 x
UART, 4x USB, 1 x Ethernet, 1 x SATA, 1 x PCIe, and 2GB RAM with
standard set-top box IPs.
This patch adds initial support to B2020 with STiH415/416 with SBC_UART1
as console and a heard beat LED.
CC: Stephen Gallimore <stephen.gallimore@st.com>
CC: Stuart Menefy <stuart.menefy@st.com>
CC: Arnd Bergmann <arnd@arndb.de>
