Currently, same stm32f429-pinctrl driver is used for stm32f429 and
stm32f469. As pin map is different between those 2 MCUs,
a stm32f469-pinctrl driver has been recently added.
This patch
-allows to use stm32f469-pinctrl driver for stm32f469 boards
-reworks stm32 devicetree files to fit with stm32f429 / stm32f469
In the same time it fixes an issue when only MACH_STM32F469 flag is
selected in menuconfig.
Fixes: d28bcd53fa90 ("ARM: stm32: Introduce MACH_STM32F469 flag")
Reported-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
The rootfs is independent from the board.
Signed-off-by: Alexandre TORGUE <alexandre.torgue@st.com>
Enable the CRC32 crypto on stm32429-disco board.
Signed-off-by: Cosar Dindar <cosardindar@gmail.com>
This patch enables USB HS working in FS mode on stm32f429-disco
with 5V VBUS enable.
Signed-off-by: Bruno Herrera <bruherrera@gmail.com>
This patch enables RTC on stm32f429-disco with LSI as clock source because
X2 crystal for LSE is not fitted by default.
Signed-off-by: Amelie Delaunay <amelie.delaunay@st.com>
Signed-off-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
This patch selects USART1 pin configuration on PA9/PA10 pins
for both Eval and Disco boards.
This patch replaces use of linux,stdout-path by stdout-path as per
"chosen" DT bindings documentation.
Doing that, the "console" argument is no more needed in kernel command
line.
Reported-by: Olof Johansson <olof@lixom.net>
New bindings and driver have been created for STM32F42xxx series parts.
This patch integrates these changes.
Note: Earlier device tree blobs (those without st,stm32f42xxx
compatibles for the rcc) could still be used to boot basic
systems. Such systems rely on the bootloader to configure the
clock gates for vital periperhals.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Reviewed-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
The STMicrolectornics's STM32F429 MCU has the following main features:
- Cortex-M4 core running up to @180MHz
- 2MB internal flash, 256KBytes internal RAM
- FMC controller to connect SDRAM, NOR and NAND memories
- SD/MMC/SDIO support
- Ethernet controller
- USB OTFG FS & HS controllers
- I2C, SPI, CAN busses support
- Several 16 & 32 bits general purpose timers
- Serial Audio interface
- LCD controller
Tested-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
