Currently, same stm32f429-pinctrl driver is used for stm32f429 and
stm32f469. As pin map is different between those 2 MCUs,
a stm32f469-pinctrl driver has been recently added.
This patch
-allows to use stm32f469-pinctrl driver for stm32f469 boards
-reworks stm32 devicetree files to fit with stm32f429 / stm32f469
In the same time it fixes an issue when only MACH_STM32F469 flag is
selected in menuconfig.
Fixes: d28bcd53fa90 ("ARM: stm32: Introduce MACH_STM32F469 flag")
Reported-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
The rootfs is independent from the board.
Signed-off-by: Alexandre TORGUE <alexandre.torgue@st.com>
This patch enables USB FS on stm32f469-disco with 5V VBUS enable.
Signed-off-by: Bruno Herrera <bruherrera@gmail.com>
Define and enable pwm1 and pwm3 for stm32f469 discovery board
Signed-off-by: Benjamin Gaignard <benjamin.gaignard@st.com>
This patch enables RTC on stm32f469-disco with default LSE clock source.
Signed-off-by: Amelie Delaunay <amelie.delaunay@st.com>
This patch adds USART3 pin configuration on PB10/PA11 pins
for STM32F469I-DISCO board.
This patch fix memory size to support 16MB of external SDRAM.
This patch adds the QSPI clock for stm32f469 discovery board.
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com>
stm32f469-disco and stm32f429-eval boards use SDRAM start address remapping
(to @0) to boost performances. A DMA translation through "dma-ranges"
property was needed for other masters than the M4 CPU.
stm32f429-disco doesn't use remapping so doesn't need this DMA translation.
This patches moves this DMA translation definition from stm32f429 soc file
to board files.
Tested-by: Bruno Herrera <bruherrera@gmail.com>
It's pretty similar to the STM32F429, but there are some
subtle changes required to boot successfully.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
