As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Now that we can handle the generic pinctrl bindings, convert our DT to it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The ehci1/ohci1 pair on the ba10-tv-box is connected to an USB-2 wifi
module soldered on the PCB, so there enabling ohci1 is not necessary.
The ba10-tvbox has the otg controller connected to one of the 2 usb-A
receptacles it has on the front, so enable the otg controller in host-only
mode.
The A10 has a few SRAM that can be mapped either to a device or to the CPU,
with the mapping being controlled by a SRAM controller.
Add the SRAM controller, the SRAM that it drives and the section that can
be used by the various devices.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Currently none of the target boards nor the driver supports
IR TX. However this pin is used in a few instances as a GPIO.
Split the pin ctrl descriptions so that only the IR RX is
configured to be used.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
In order to lessen the amount of duplication of the DT tree, ease the
new and follow the trend that prefers to use label based references
when overriding DTSI nodes, convert the board to this syntax
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
Prepare the device trees to use the C preprocessor.
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
device trees under a GPL/X11 dual-license.
The ba10 tvbox is an A10 based android tvbox, with 512M RAM, 8G nand flash,
rtl8188ctv usb wifi 1 USB-A receptacle hooked up to an EHCI/OHCI controller,
1 USB-A receptacle hooked up to the OTG and 100Mbit ethernet using a
rtl8201 phy.
The PCB is labelled ba10 hence I've named the board ba10-tvbox. It is used
in noname allwinner A10 tv-boxes.
