path: root/arch/arm/boot/dts/sun4i-a10-gemei-g9.dts
2018-02-13ARM: dts: sunxi: Switch MMC nodes away from cd-inverted propertyTuomas Tynkkynen
Using the cd-inverted property is not useful when GPIOs are used as card detects since the polarity can be specified with the usual GPIO_ACTIVE_(HIGH|LOW) GPIO flags. It has also caused confusion for U-Boot developers, so migrate all sunxi boards away from cd-inverted. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2017-10-13ARM: dts: sun4i: Provide default muxing for relevant controllersMaxime Ripard
The I2C's, MMC0 and EMAC controllers have only one muxing option in the SoC. In such a case, we can just move the muxing into the DTSI, and remove it from the DTS. Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-13ARM: dts: sun4i: Change pinctrl nodes to avoid warningMaxime Ripard
All our pinctrl nodes were using a node name convention with a unit-address to differentiate the different muxing options. However, since those nodes didn't have a reg property, they were generating warnings in DTC. In order to accomodate for this, convert the old nodes to the syntax we've been using for the new SoCs, including removing the letter suffix of the node labels to the bank of those pins to make things more readable. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-09ARM: dts: sun4i: Change LRADC node names to avoid warningsMaxime Ripard
One of the usage of the LRADC is to implement buttons. The bindings define that we should have one subnode per button, with their associated voltage as a property. However, there was no reg property but we still used the voltage associated to the button as the unit-address, which eventually generated warnings in DTC. Rename the node names to avoid those warnings. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-06ARM: dts: sun4i: Remove all useless pinctrl nodesMaxime Ripard
The gpio pinctrl nodes are redundant and as such useless most of the times. Since they will also generate warnings in DTC, we can simply remove most of them. Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-14ARM: sunxi: Drop mmc0_cd_pin_reference_design pinmux settingChen-Yu Tsai
As part of our effort to move pinctrl/GPIO interlocking into the driver where it belongs, this patch drops the definition and usage of the mmc0_cd_pin_reference_design pinmux setting for the default mmc0 card detect GPIO pin. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-12-26ARM: sunxi: Convert pinctrl nodes to generic bindingsMaxime Ripard
Now that we can handle the generic pinctrl bindings, convert our DT to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,pull propertyMaxime Ripard
The allwinner,pull property set to NO_PULL was really considered our default (and wasn't even changing the default value in the code). Remove these properties to make it obvious that we do not set anything in such a case. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,drive propertyMaxime Ripard
The allwinner,drive property set to 10mA was really considered as our default. Remove all those properties entirely to make that obvious. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2015-12-18ARM: dts: sun4i: gemei-g9: Enable PA GPIO pin configurationPriit Laes
PA GPIO pin (PH15) controls power to external amplifier (FT2012Q). Signed-off-by: Priit Laes <plaes@plaes.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-17ARM: dts: sun4i: gemei-g9: Enable sun4i audio codec supportPriit Laes
Gemei G9 has internal speakers and headphone jack. Audio switching from internal speakers to headphones is automatically handled by extra FT2012Q audio amplifier chip that works out of the box. Signed-off-by: Priit Laes <plaes@plaes.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-17ARM: dts: sun4i: gemei-g9: Use reg_ldo2 instead of reg_vcc3v0Priit Laes
ADC seems to be using ldo2 for reference voltage. Signed-off-by: Priit Laes <plaes@plaes.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-17ARM: dts: sun4i: gemei-g9: Convert to use axp209 regulator nodesPriit Laes
Add regulator nodes for axp209 using the axp209.dtsi include. Signed-off-by: Priit Laes <plaes@plaes.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-09-27ARM: dts: sun4i: gemei-g9: Add accelerometer (bma250) IRQPriit Laes
Add IRQ configuration for bma250 accelerometer. Signed-off-by: Priit Laes <plaes@plaes.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-10ARM: sunxi: dt: Remove the FSF addressMaxime Ripard
The FSF address triggers a warning on checkpatch, saying that the FSF license is already present in the Linux source code, and that it has already changed in the past. Remove it from our DT, as suggested. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: sunxi: DT: Add stdout-path propertyMaxime Ripard
Add UART aliases and stdout-path property for all the Allwinner boards so that we won't have to rely on the bootargs' console= value, while working with legacy bootloaders. While we're at it, also remove the mentions of earlyprintk in the bootargs, that will remove our default bootargs entirely, and allow the kernel to boot on a system even if DEBUG_LL is configured for another system. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: dts: sun4i: Add initial dts for Gemei G9 tabletPriit Laes
Gemei G9 is an A10 based tablet, with 1G RAM, 16G NAND, 1024x768 IPS LCD display, stereo speakers, 1.3MP front camera and 5 MP rear camera, 8000mAh battery, GT901 2+1 touchscreen, Bosch BMA250 accelerometer and RTL8188CUS USB wifi. It also has MicroSD slot, miniHDMI, 1 x MicroUSB OTG port and 1 x MicroUSB host port and 3.5mm headphone jack. Changes since v2: * Fix syntax error (brown paper bag release) Changes since v1: * Added sun4i-lradc keymap * Added TODO note about missing IRQ pins for bma250 * Fixed formatting issues and removed external URLs Signed-off-by: Priit Laes <plaes@plaes.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
