As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
It seems that recent kernels have a shorter timeout when scanning for
ethernet phys causing us to hit a timeout on boards where the phy's
regulator gets enabled just before scanning, which leads to non working
ethernet.
A 10ms startup delay seems to be enough to fix it, this commit adds a
20ms startup delay just to be safe.
This has been tested on a sun4i-a10-a1000 and sun5i-a10s-wobo-i5 board,
both of which have non-working ethernet on recent kernels without this
fix.
Cc: stable@vger.kernel.org
The Jesurun Q5 has the musb hooked up to an usb-a receptacle, enable it
in host-only mode.
The A10 has a few SRAM that can be mapped either to a device or to the CPU,
with the mapping being controlled by a SRAM controller.
Add the SRAM controller, the SRAM that it drives and the section that can
be used by the various devices.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Currently none of the target boards nor the driver supports
IR TX. However this pin is used in a few instances as a GPIO.
Split the pin ctrl descriptions so that only the IR RX is
configured to be used.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
The Jesurun Q5 has a black plastic casing with the approximate dimensions
of 100mm x 100mm x 24mm with rounded edges. In terms of hardware it
features an Allwinner A10 SoC with 1GB RAM and 8GB of NAND flash. The
external connectors are: 2x USB-A female supporting USB2.0, 3.5mm female
jack for audio, HDMI female, SPDIF, RJ45 LAN and Power. In addition the
device has 1x red LED (hard wired to power) and an programmable green led.
On the board there is also an unpopulated IR receiver and the UART.
The devices is equipped with an AXP209 PMU.
For more details see: http://linux-sunxi.org/Jesurun_Q5
