As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
The Olimex A10 OLinuXino Lime features an eeprom that is always on the
board. This patch adds it to the dts.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
Enable the otg/drc usb controller on the A10 OLinuxIno Lime.
Signed-off-by: Remy van Elst <relst@relst.nl>
The A10 has a few SRAM that can be mapped either to a device or to the CPU,
with the mapping being controlled by a SRAM controller.
Add the SRAM controller, the SRAM that it drives and the section that can
be used by the various devices.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
In order to lessen the amount of duplication of the DT tree, ease the
new and follow the trend that prefers to use label based references
when overriding DTSI nodes, convert the board to this syntax
The Olimex A10-Lime is known to be unstable when running at 1008MHz.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
Prepare the device trees to use the C preprocessor.
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
device trees under a GPL/X11 dual-license.
Acked-by: Carlo Caione <carlo@caione.org>
At a node for the axp209, and where necessary the i2c controller to the dts
for various boards. Note the axp209 regulators are omitted as we don't have
any use for them yet, and on some boards were not sure how exactly they are
wired up.
Adding support for just the axp209 without the regulators is still useful, as
it will give us power-button and poweroff support.
Signed-off-by: Carlo Caione <carlo@caione.org>
[hdegoede@redhat.com: Drop the regulator bits for now]
Tested on a subset of these boards, for the others boards the settings match
the ones of the tested boards according to the original firmware fex files.
This add support for the A10-OLinuXino-LIME:
https://www.olimex.com/Products/OLinuXino/A10/A10-OLinuXino-LIME
A low cost Allwinner A10 based dev-board, with sata, ethernet, hdmi and 2x USB.
